RevLimitLaunch
- 06 MS6/03.5 MSP
sick, now ill add for something like the 5th time to get on that pnp business lol...i want it more than ever.
EE-Geek said:Thanks for the vid clip, I've seen a few of those machines before. For how slow it moves, depending on how many parts are on the board, it could take quite a while to make the hundreds of them you are planning on producing!
The moment I thought this something else occurred to me... Seeing as half of the fun we have is the tweaking and upgrading (not just driving a modded car), why not provide another way to offer this? I'd love to buy this when it finally comes out but I know $700 will prevent me for at least a little while; it'd be great if you made this available as a kit we could assemble ourselves for a bit less $$$. This may come across as a bit bizarre but I probably would enjoy building and installing this more than I would enjoy installing a ready-made device. This may be because I'm a "double 'E' " but, if the board isn't too complex, there may be a market for something like that.
I guess not everyone has a hot-air soldering iron for surface mount devices but I figure you made it surface mount for automation and not for size constraints. A through hole board might be possible then?
(Queque the laughing and pointing at the EE Geek)
Oh, and you're not looking for test engineers are you![]()
EE-Geek said:Did the assembler break?just kidding.
Even some descriptions and docs on your webpage would be nice to have just to get familiar with installation, etc.
InlineTwin said:I would be interested in building the board from a kit as well, but it would really depend on the discount. It probably costs CPE less to build it than I think it is worth in time spent on assembly, but I would be interested in any case. I've designed and built 4-axis cnc machines for foam cutting and the boards I've built had 700+ pinouts with a 44 pin microprocessor. I did not find it hard to do the assembly and I am just an aerospace engineer! (Ha, we all know AE's are way cooler than EE's!) I would just lay a piece of solder across the pins and run the iron over it. Solder flows right into the joints. I think it would be easier for the less experienced to do surface mount than through hole.
CPE would have a harder time with validating the components functionallity before sodering as it is very possible damage may occur to what is likely a sensitive microprocessor chip would be due to soldering or humidity changes. How can they control this when it is assembled? Most microchips have a limited shelf life before soldering because of humidity. This would also be a limiting factor.
MS6mike said:hey jordan any news on the FMIC ?
MS6mike said:he actually didget one! it was at 276awhp and 300ft tq at 16psi! if i am not mistaken!
EE-Geek said:sweet! Is that stock otherwise? It would be nice to get numbers for the Standback on stock, CAI, CAI + DP, DP + catback, etc.
I wish there was a release date. That would be so much better than checking their page and the forum multiple times a day. I feel like I'm OCD. Oh right, I am...
MUSOM said:I might be able to help out with the dyno results. I've currently got CAI, DP, and full exhaust (all CPE). I'll be doing a pre-dyno with my current mods, and then a dyno with the addition of the FMIC and EMS. Maybe that will help some. I should be doing in within the next couple of weeks. Just waiting on the release.(alright)
flyrevs said:Quote "The guy who made 272whp and 300lbft. (a 32whp and 40lbft. gain over untuned) had an AEM cai (along with a nasty fuel cut), cp-e downpipe, and cp-e catback exhaust. The tuner not only added a great deal of power, but he was also able to eliminate the fuel cut that the intake was causing. We asked for dyno graphs, but we have yet to receive them."
This does not seem right - the cp-e downpipe, and cp-e catback exhaust alone are advertized at " The best part is when the catback is paired with our upcoming downpipe, one can expect on the order of 30hp and 40lbft of torque to the wheels!"
So the cp-e downpipe, and cp-e catback exhaust add 30hp and 40ftlb , add a CAI and standback and get the same ? How did the tuner add power? Looks like bad math to me. I must be missing something.
Can someone explain this? Thanks
Yes,I am referring to the Speed3, but I thought the 6 would be about the same since it has the same engine. I was under the impression the the cp-e dp and cat back added 30hp 40tq on the speed. I thought the tuner and CAI would bump the 30hp 40 tq up from there. I'm not bashing cuz I love CP-E and what you guys are doing for the Speeds, just wondering why the hp-tq numbers are not higher with the standback / CAI. Thanks for your help.www.cp-e.com said:Well first off, I think you may be looking at the dyno results for our SPEED3 equipment, whereas these numbers were generated by a SPEED6. I'm not sure if that's confusing you? I'm just not sure which part you're questioning? Are you querstioning the total power the customer was making, or the gains from the Standback?
The car came in with the turbo back and intake installed, AND THEN they tuned the car. With just his bolt-ons and no tune, the customer made 240whp/260lbft. Altered Atmosphere's owner and tuner, Mike Mahaffey, told us that the car had a nasty fuel cut and was running extraordinarily lean because of the AEM intake. After adding some fuel, upping boost to a modest 16psi, and pulling a degree of timing up top, they made 272/300. This was a conservative map however, since a little more boost and timing (below the knock threshold of course) could make a significant difference.
Is that clearer? If not, explain where the confusion lies and I'll do my best to clear things up.
Jordan
flyrevs said:Yes,I am referring to the Speed3, but I thought the 6 would be about the same since it has the same engine. I was under the impression the the cp-e dp and cat back added 30hp 40tq on the speed. I thought the tuner and CAI would bump the 30hp 40 tq up from there. I'm not bashing cuz I love CP-E and what you guys are doing for the Speeds, just wondering why the hp-tq numbers are not higher with the standback / CAI. Thanks for your help.
www.cp-e.com said:No, no problem, I didn't take it that way (drinks)
I think the problem is that as you add performance parts to your car, the tune drifts as the stock maps are no longer ideal for the newly added hardware. In other words, individually, these parts may add a lot of horsepower, but when you install all of them on an untuned car, they may not make nearly as much power as they did individually because their combined affect on the OE tune is detrimental despite the added breathing benefits. Hence the lean mixture that Mike was referring to. So the tune essentially made the most of the new combination. In an ideal world, if the ECU could constantly tune itself, then I would imagine that he would have made closer to 260whp with the modifications he had on the car (boost was increased slightly too). This is why tuning after you make modifications to the car is so important.
Another complicating factor is that these cars can dyno stock anywhere from 190whp to as high as 230whp. That's a variance of as much as 40whp! Here's someone who made 193whp stock:
http://tinyurl.com/2mz7rx
and here's someone who made 225whp stock:
http://tinyurl.com/2kptyv
I also got a ride in the car in question yesterday, and let me tell you that it literally transformed the car. The difference from tuned to untuned felt like the difference between a full bolt-on car and a stock car. The customer said that he has a friend with an Eagle Talon that typically beat him by about three car lengths whenever they race, and now he says he has no problem pulling on the Talon![]()
Jordan
