probably not, the ATP has a tendency for small spikes. [edit: no shame in trying. generally the mantra is to use a dedicated line to the WGA anyways]
blowing up engines in these cars cant be boiled down to one thing, its more like "when the stars align". its the bad tune, weak rods, bad tranny, etc, etc etc.
if you have a boost spike too low in the RPM youre out a tranny. the torque added after spooling is just too much for our third (and sometimes fourth) gear. the best way to avoid the issue is to avoid boosting past a couple psi when youre in third or fourth and are below 3500 on the tach. personally, i dont boost in third, fourth, or fifth at all unless im over 4000.
the other issue is the engine... basically, if the spike is at that 400-500 RPM window where the lean spot in the WOT open loop is, it leans out and detonates until you spin a bearing or throw a rod. nothing you can do to avoid that except get a tune and hope you have a freak engine... some have survived 12psi with no tune or FMIC, some have blown totally stock.
