Yep yep yep. My hands are feeling nice, but it is done. I ended up using a 45* off of the turbo and a 90* at the pan. It worked really well. The hose portion part is less than 8" long. It took a couple tries to get it fitting perfect, but I almost had it the first time perfectly. Then I freaked out because I forgot the other dp was bigger. Turns out it fits easier with the GHL pipe. Oh, and the GHL dp clears the pan fine as well.
Vice is essential. I also borrowed a set of clippers made specifically for cutting AN lines... that helped so much. I had no problem what so ever with fraying. Slid in with ease each time.
Anyways, I have to return that tool to the shop. This shop rocks, probably the only place in town with AN stuff. Unfortunately it is at least a 30 mile roundtrip AND I've gone there two times this week, now going on three. Oh well, better than overnight shipping! I'm also going to have an extra O2 bung welded on.
What kind of drill bit do people use for the cast iron?! Holy crap. I bought a "heavy metal" cobalt drill bit and it does nothing. I managed to make a dent similar to it being shot with a bb gun. That sucks! Maybe this shop can do it. Or maybe I'll have a bung welded in the pipe, probably be accurate enough.
I'll have pics later, the camera is charging and I gotta get this stuff done!
P.S. Kansei, thanks for all the help so far
