My favorite.
Assuming that the air filter is actually bad, subtracting its price ($25) from the total cost gives you $65. Replacing the filter takes 5 minutes, so that's an hourly rate of $780!!
My favorite.
I was going to start a thread awhile back. The change your cabin filter in 10 seconds challenge.Assuming that the air filter is actually bad, subtracting its price ($25) from the total cost gives you $65. Replacing the filter takes 5 minutes, so that's an hourly rate of $780!!
10 seconds? Really possible if you practice doing it.
I was referring to the cabin filter. 10 seconds is doable. I've done it.Takes some of us 5 seconds to open the hood and support it. Another 5 seconds to unsnap the filter cover, 2 seconds to remove filter and inspect. 10 seconds to vacuum or wipe out the filter box. 5 seconds to un rap filter box and inspect the filter seals. 2 seconds to place in box while making sure the seals are in place. 2 seconds to put the cover on and snap in place and 3 seconds to wipe of finger prints and close the hood.
I can't see a good conscientious job preformed in 10 seconds but, that's just me. Ed
Hamilton Mazda NJWow!!! That dealership is really trying to rip you off! Care to share the name and location?
Ugh, those guys are right around the corner from me. Haven’t needed service yet, hope I dont as I tend to diy. I avoided buying my cars there as they were pretty shady. Not disclosing or showing damage in pics, have heard other stories not so good about them. Used Faulkner in PA.Hamilton Mazda NJ
Isn't this one of the easiest things to change on your own? Took me like 5 minutes.My favorite.
Hamilton Mazda is with in a mile from me, i tried them twice and both time i felt they have shady practices. I went to second opinion in local shops and they confirmed everything is fine. In Past i used Open road Mazda East Brunswick and can say they are still better. I am planning to use local shops going forward.Ugh, those guys are right around the corner from me. Haven’t needed service yet, hope I dont as I tend to diy. I avoided buying my cars there as they were pretty shady. Not disclosing or showing damage in pics, have heard other stories not so good about them. Used Faulkner in PA.
can I ask where you did take your car for service/inspection, maybe I’ll use them if I need to.
btw, many dealers push these high margin services and some are shady. I took my pilot in to a local Honda dealer and they told me my engine and air filters were dirty even though they were just replaced by me less than 7k miles ago. I checked them, clean as a whistle. They never even looked at them. You just have to cautious when a dealer recommends something. Follow the dashboard or service manual and you’ll be fine.
i also recall sitting next to a guy in an Acura dealer service area and the advisor was telling him he needed a new cabin air filter at a cost of $135!!! Guy saud ok to the service. I can install one in 9 seconds and at that time they were $8 on Amazon.
Yes indeed!2016.5 ..... Best cx5 made btdubbs
I changed the brake fluid the first time after 20 years and 182K miles of the service on my 1998 Honda CR-V.But, I'll admit, we never had the brake fluid changed in my wife's old 09 CX9 after ~12 years and 185k miles. And, I just had it done for the first time on my 100K+ mile 2014 Explorer.
Honestly, if I only want said Mazda dealer doing the maintenance for my 2016.5 CX-5 AWD at 57K miles, I may consider ATF change on transmission、gear lube change on front transfer case and rear differential、brake fluid change、and serpentine belt and water pump change with belt tensioner replacement (only if $278.48 includes belt tensioner replacement).I have Mazda CX5 2016.5 with 57k miles on it. In my recent visit Service Center Recommended bunch of services. I am looking for your suggestion and priority on it.
For some reason, many car manufactures including Mazda and Honda don’t recommend any brake fluid change in their maintenance schedule for US market, but they, Mazda and Honda, do recommend brake fluid change with 2-year interval in other regions.
Just use brake fluid tester and change the brake fluid when the moisture level is reaching 2%.
I ordered one exactly like that from AliExpress few years ago when the shipping from China was still pretty fast and reliable. There’re much more expensive ones on Amazon right now. But to me such tool really is only used for verification of moisture level in brake fluid, at the time I’m doing any kind of the brake job and have decided to change the brake fluid at the same time, no matter if the moisture level is below 2% or not. I won’t just change the brake fluid only if the tool says the moisture level is high.Is that the tester that you have a recommend? I need to get one of these.
