Noghri2112
- 2016 CX9 GT
Mine is actually just resting against the console that houses the camera on the windshield, you can actually see it in the last pic of post #5 on the first page of this thread. There might be room to jam it up behind the headliner with the rest of the cable, but I didn't bother with trying.
Thanks for information. I finally got around to getting dashcam and the Invisicord. IN the picture I thought it was larger than what it appeared. I thought it was going to be a huge power brick for some dumb reason.
Camera works, but I noticed when we put the vehicle into Reverse and even going from Drive to Park, it can power off and then back on. I am using the power connections on back of mirror that provides power only when vehicle is on. I didn't want to possibly drain the battery.
I thought I saw post about disabling something in mirror to not lose power when shifting, but haven't found anything.
Anyone have issues where they used the switching power connections(blue/black) on back of mirror and dashcam will power cycle when shifting?
I bought the Invisicord with fuse and mini pins. Dashcam I have is the Viofo A119S V2
UPDATE:
I fixed my issue. I thought there were 2 ground wires in the power connection for mirror and interpreted previous posts that you plug the ground near the one you plug in for positive side. I moved my ground wire to the single black wire by the green/black connection and tested it out and it stayed on when I shifted into reverse. I originally had it plugged into the ground wire next to blue/black. What I thought was proper ground wire also appeared to be dual colored blue/black. Anyways, looks like I fixed my issue.
Thanks!
