Adding Sub and Amp question (2022 CX-5)
2022 CX-5 CE
Looking to add a line out converter for a sub, and amp on 22 CX-5 non Bose system.
In need of a diagram for which, and where the speaker wires are behind the glove box to tap into for the LOC.
Depending on if you had the factory amplifier under your front seat or now.... In my 23 CX-5, - under the seat. The plug you need is in the middle and should only have 8 wires going in to it - (rear speakers) Yellow & light green, (front speakers) Brown and dark green.
Upvote 0
What are the colour codes of wiring for rear speakers on input side of amp - 2023 amp under seat model as I will make loom to save cutting wires and fitting LOC as only usually 3V max anyway?
Upvote 0
If it's anything like my CX-9 (and it's probably identical) you can't capture the signal before it hits the amp. It's a CANBUS signal, and therefore useless to us unless you're an electrical engineer. And yeah, I wish I was.
Upvote 0
I wish too - manufacturers make upgrades difficult with integrated canbus.
On my 2022 rear speakers are shocking weak due to preprogrammed infotainment which means I'll probably have to tap front speaker wires for sub rather than rears. Anyone know if software or firmware downloads available to improve? Tapping front speakers means transmitting beeps, fading etc from sat nav - not ideal...
Upvote 0
