Just bear in mind cutting/stripping spark plug leads isn't exactly the same as other wires.  There's other things in there, so if you know that you'll be fine.  Personally, I have no problem having Magnecor make mine.  The total cost of the custom wires is less than the "correct" crimping tool so it's worth it to me.  That and I think your turbo KL won't be quite as sensitive as my built 13B when it comes to the ignition.  It's VERY important to still get a full, consistent spark when the engine is turning at speeds upwards of 9,000 RPM...
	 But yeah, 3rd KL swap. Though the Milly shouldn't count since it wasn't technically a swap. Stock to stock is easy peasy.
