i havent had that issue at all with the LX cluster i have. reut, im guessing your issue with the ring popping out is also related to that.
i will pull my MSP cluster off next time i go into the shop to see if i can get the same issue. in the meantime... did you try seating it at the top and pushing the bottom in? also try applying a little inward pressure when you push it down...
