 - 2000 Protege ES
I'll be ordering mine tomorrow, and get the c/f bezel to go with it.
don't forget to post pics please!!!
well here's the rub - the set i mailed out to matt were extremely tight, and i tried to loosen them up a little. maybe it was too much... but as a forinstance, you probably got one of the pre-revision small rings and one of the post-revision... the size difference between the two is .002" - about the same as the main bearing clearance - and it makes that much of a difference.its in an 03 protege 5 cluster, and yeah its in all the way. push real hard, tried twisting it to find a sweet spot to no success. it will stay in but once i flip the cluster over and tap it lightly the ring will fall out.
the one i put around the tach fits great and the one around the gas/temp gauge seems a little big but it definitely wont come out when squeezed in.
im not positive what causes this, but i honestly think its just a very slight shade difference between the two runs of stock, despite being the same alloy. you can try sanding them a little - face down on a flat surface, with 100-140 grit to see if you get a similar shade, but aside from that i dont know what would help. they are sanded here with 100 grit paper designed to be used on aluminum.well the bummy thing about it is that the speedo and tach have a great halo affect but the other one doesnt light up as much
oh - OK. i have noticed subtle shade differences, but i figured i was probably the only one. glad to hear that still holds true.
Not to give you a ribbing, but its been much longer than 2.5 months. loldont say anything about a long wait when wagonbacker is in the thread - he gave me a material deposit to start working on some CF stuff right around when i first came out with the vacuum blocks... like 2.5 months ago... hes been patient though, and has let the rings take priority. so just try not to have him catch you saying that.
well ive been working on it since like march if you want to get really technical. paypal says i got your cash deposit on... april 16. so not even 2 months.
and right after i defended you...
both sets are on their way. bschatz, yours are also in the mail... i saw you had an LX so you have the looser ring, but if you run into any fit issues with it, let me know.Just saw that mine were on the way, is this both sets or just one? I'll try to get a few pics iafter I put them in.
did you do the "tap test?"Installed my rings last night. I'll post pics/review on Thursday probably. The speedo ring seems to be a shade too large, but the 2 small rings fit perfectly snug.
