rear camber isnt adjustable, but toe definitely is...and if you like your tires at all, you'll adjust it
I just aligned mine tonight ^^
if your alignment was perfect before and you put new struts in...everything would have moved equally on all 4 corners. So your alignment is different, but it should be ok. Especially if you kept the dots in the same spot.
Your camber and caster will have changed (due to a slight increase in ride height) but since they're even, and eventually will be back to a normal ride height, you should be ok.
joneb: I'd feel 85% comfortable telling you you're probably ok...the other 15% would be the banging having slopped your toe up. thats what mine did (RF strut so blown you could push it all the way in, and pull it all the way out with *no* resistance)...toe was out almost half a degree from stock. My camber and caster required no adjustment.
joe: I've heard negative camber helps autocrossers...but its effect on tire wear and general driving is pretty nasty (at least, when you get the camber to the point that it truly starts helping turn-in). Negative camber, when driving straight, puts a lot more stress on the inside of your tire tread...wearing it out maturely, and it also makes your steering much more sensative.
I think I inadvertantly gave myself some wicked camber when I changed my struts out (in a rush, forgot if my dot was to the inside or outside) and it was like I was either driving straight...or I was turning sharply. It was fun, but I knew it wasnt good![]()
Ok so just a question, when you lower your car (change out springs and struts), and have a shop do the alignment, should you go to a tuner shop or any shop will do? I ask cause I remember a while ago I had tiresplus do it and they said they align to the car's specs. So since mine didn't have the stock suspension, I was worried it would be all screwed up...is that true or am I wrong?
So, camber bolts won't adjust camber in rear?
Thanks, I have 2 sets but haven't had to use them since my alignment shop hits my specs without them. No wander, no tire wear, no nothing, just 50 for a 4 wheel with 6 month warranty.You should be able to buy after market cam bolts for the rear that should change the camber alot of people with coil overs have cam bolts in the rear
