will this offset work
twistiert
Mazdaspeed ,Protege
ok the rim size is 18X7.5 with a +42 offset will that offset work o will I need to roll the fenders or what thank you
You'll need to roll the fenders. +45 is the minimum offset for 18x7.5 wheels.
It depends on what size tire you go with. I've got 18x7.5" wheels (+42 offset) with 215/35/18 tires and lowered about 1.5" and have no rubbing issues.
If you get that tire size which is the recommended tire size for an 18x7.5" wheel on our car you will not have any rubbing issues and will not have to roll the fenders (there isn't much to roll anyway).
Mark
I have a +42 off set with 215/35/18 and the only time my tires rub is when i have a couple of people in the back seat, and that is not very often.
Sorry for the bad information, I think I have +45 wheels plus I have a stiff suspension so that helps with not rubbing. I haven't heard any rubbing from the car whatsoever. I rarely have people in the back but I do corner hard when I take the car out.
+45 would be the minimum, so would 18x7.5 +48mm work better? cuz i'm looking
if these would fit my msp
I have 18x7.5 with 45 offset and 215/35/18 tires and have no problems with rubbing or anything.
