The manual also says:
The level is normal if it is between the MIN and MAX marks.
And it was also true of the GM and even Mercedes cars I've had.
So half-way is fine.
Unless you're trying to protect your reputation amidst issues with oil burning engines. In that case, that is one of the only reasons someone would be near the MIN line, and you should have them fill it to MAX to buy some time.
The manual is accurate.
And I stay away from the MAX line because I don't want to take the
hit to power or economy.
