stainless steel brake lines are going in next with some ate super blue. Tokicos as well, but have already installed my progress rear sway bar.
Proper!
I like a company that is able to make exactly what you want!
I am a BIG FAN of CR3
What were you having the AWR pan welded for? Do you have any issues with sealing? I swear this is the 3rd time Ive tried to reseal this thing and it keeps seeping oil from somewhere. I may buy studs to replace the bolts, dont trust them anymore with how many times they have been retightened
It leaks Through the Welds.
For something that is +$400, I don't understand the laziness of not welding both he inside and out. It literally took my friend Joe, 10 minutes to TIG it.
how the hell does someone dent my car here? the door is fine so its boggling my mind. good thing im getting cheater panels done this spring to fix the rust
Here is a real close up of the external welds and the DOC B Oil Return in the windage. AN10
There is no coating on the welds in this picture, They are bare metal.
The pan is going to be media blasted today and then I will play with what to cover it with.
I took a look under the hood for the first time in a month =/
The power steering pressure hose is starting to leak where the rubber hose is crimped onto the metal pipe coming off the PS pump. Does anyone know if I can change it without dropping the steering rack?
Replaced the the ignition coil for cylinders 2 & 3. Now I have a matching pair since the other one took a dump about 2 months ago. There was some oil in cylinder 2 around the bottom of the coil boot, but I think that was from the old VC gasket leaking. The other boots were dry and I don't smell oil in the exhaust.
That, and full tank of gas.
I just got done buying new coil wires for 1 and 4 seconds ago...
I met another member. I bought wheels off him and I am about head out in my Pro5 with wife to go play some pool, then do some shots in her Birthday Honor with said member.
