fishdonotbounce
Registered Zombie
- 08.5 CWP Speed3
Well s***, let us know how that thing ends up. That's a pretty cool project.
What is the stock piping on the P5...I was told to go 2.5 on this exhaust...it will all have to be cut up as this one goes out the left instead of the right...
I figure the most it will cost me to get done is around $100...that is what the shop said and that is the Very high end of doing it...
Worth it I guess...I just like being different...lol...
I will tell you this the MZ3 exhause on a NA 3 sounds damn good! So I can imagine that it will sound good on the P5. Like you said it will all have to be peiced together due to the 3 and the pro's exhuast are on different sides.
Used engine restore for the first time today and put some belt dressing on the belts to quiet those suckers down a bit. Didn't do too much driving today so no impressions of the engine restore yet.
Oh and I am looking for an Injen CAI if anyone has one for sale.....
(cryhard)Just found out that Azenis RT-615s won't get you out of your yard if there is the slightest hint of mud. Hahaha. What a mess now.
(cryhard)
What did you learn?
I shouldn't park in the yard.
Just got inside from working on my spare engine. Today I managed to remove the valve cover, cam gears, cams, cylinder head and torque converter. I'm kind of at a stopping point until I can borrow/purchase an impact wrench to remove the drive plate and crank pulley. With those off I can remove the water pump, oil pump and front and rear main seals. After that I need an engine stand so I can remove the oil pan, lower crank support and everything else. Then I can start gathering and assembling the new bits...
BTW, I'll be selling everything except the block, crank and oil pump so if anyone needs anything...
