I've driven the car 66.4 miles with no strange leaks, smells, or lights... So, that's got to count for something...
Edit: I actually take that back... The heater outlet hose came off yesterday... This, my friends, is why I don't let other people touch my cars. Something always gets overlooked or damaged or half-assed.
*The rear main seal retaining plate was left loose which is why I had to pull the transmission. It was POURING oil out of the bellhousing.
*The EGR pipe was left finger tight.
*Anything aftermarket (vacuum hoses/wiring) was left loose.
*Heater outlet hose didn't have a clamp on it resulting in it popping off and losing coolant.
*Various bolts/nuts with damaged heads.
*Driver side axle boot has a large split in it and throwing a metric **** ton of grease.
*Crank sensor wiring damaged. (switched it out with one of my other 3)
*Newly painted valve cover scratched all to hell.
*Wire and wire looms routed across hot/moving components.
Sure, not having to waste my free time at the shop doing it was awesome, but having to go back and fix these things is annoying.
