Wagonbacker9
- 2004 'Hoe
Ill try this tomorrow. See if it helps any. But autozone still checks CEL right? Sorry im on 3hrs of sleep and im in dumb mode.
yes, they do.
pretty sure that doesn't work... yes?If you get an ABS code they will probably try to check it with the same scanner. lol.
Yeah, I put a really nice codescanner on my car (made by bosch, costs $2000+ on ebay used, model escapes me) and it didn't pull the ABS code. its gotta be a different scanner and likely on a different port.
If you want to disconnect the AFC you have to take it out completely and then reconnect the wires in the ECU compartment. I was having the same issues you were having it sounds like and i just checked all my connections and sure enough I had a bad connection so i re soldered it and wala it was fixed.
My car was either way rich driving or at --- on the wideband.
We have a 5k snapon scanner and it will read air bags, ABS, engine codes and all kinds of things. Pretty much if it lights up on the dash it will read it.
but is it through the OBD2 port?
so if iwere to take my car to my local mazda dealer they could probably tell me why my abs light is on? i wounder how much theyd charge
hey there, got a question...
went up the hills with 3 other msps the other day and i felt like sliding all the way so i was thinking of getting a set of hankook v12s but on the other hand want to get the power exhaust from corksports as well as the motor mounts,
pretty tight on $$ so its either the set of tires or the exhaust and mounts...any ideas? everything's stock except for a sri as of now it would be great if anyone can enlighten me (bowdown)
