no problem, hopefully that works for you, I was really surprised and happy when it helped a lot with mine, now I just have to figure out why it keeps going rich on me after I unplug the comp. and after a day or so, but I think I just need to keep tuning it until I actually get a good map going
got the wideband installed last night. along with the new studs for the passenger side motor mount. all is good. next purchase will be new mm all the way around. any suggestions? and closly follow that witha clutch and flywheel
I still don't get why people have issues with the vibrations. I've got a 95 duro rear mount and it really doesn't bother me.
I've got all 4 AWR mounts, 70 duro. They don't bother me a bit. I've had some extra vibes @ idle lately, but thats because my idle has been going nuts. I think my alternator might have finally crapped out.
personally I think replacing MSP motor mounts with "OEM duro" is about as smart as mazda using the same engine mounts for the 2.0l Mz3 that they use in the MS3.
Bad engine mounts are a major contributing factor to diff failure... and adding a little cabin vibration is a small price to pay for better shifts, cleaner power application, and most importantly MORE RELIABILITY.
+100000
Get the AWRs; you WILL NOT regret it. If you don't want too many vibrations, get the 70DM and be done with it.
i get insane vibrations when the ac is on and car is rolling in neutral. you can actually see the dash going up and down. otherwise they're not that bad.
rr racing/awr inserts, medieval full rear mm. dont remember what duro they said it was.
retrofitting projectors into my headlights...one done and one to go, tilted front license plate bracket, will die upper interior black soon
I bought the corksport inserts (front and rear) but only managed to install the front ones. Noticeably better shifts and only minor vibration increase. I can't get the rear in since one of the goddamn bolts is stripped. It's literally the only thing from stopping me from changing it out, which pisses me off :(.
Because I'm basically stuck with the stock mount in the rear, does anyone have input on if I should get a beefier front mount, like AWR 90 Duro vs the corksport inserts?
Took a few months for vibes to stop bugging me. My shuddering dash on ac and cold start still bugs me but meh. Shifts are alright but still notchy.
Im sure when i change out the suspension and run lower pro tires the mm's will be the last thing i b**** about hah
finally gave up on my bearings, gonna have a shop do it. Just to involved for my knowledge and comfort level at this point with working on it. Did manage to paint the calipers, install ss lines, gt spec trailing arms and corksport 80 mm exhaust. Not a complete waste of time, but not the best use either
