u used the mx6 tranny?? is it the same one the 2.0l uses in the pro already?
one last thing, the kl-ze, is it ob1 or 2?
The MX6 V6 tranny and the I4 tranny are INTERNALLY the same thing. the V6 tranny however has a different bell housing.
You can get ahold of OBD-II KLZEs.
They came in the later JDM Mx6s, but most of the OBD-II ZEs will be out of the 96+MS8s in japan.
they are alot harder to come buy tho.
your best bet would be to either A) get a obd-I ZE and concert it which is not very hard, just a couple more wires to run.
or B) just get a usdm 96+ klDE and swap over the 4 basic parts from the ze
Cams, Pistons, Heads, Intake manifold, or just upgrade them to better ones.
Dont know much about the 3rd gens, havent realy worked aroudn them too much. But, Doom spun u will NEED to run your P/S if u dont or if u remove it it will seize up your waterpump,
good ups, i was gonna say that too.
you'll cause some real problems if you disconect the P/S
Just a quick question: After the swap, is there room to turbo it as well, or is it so cramped you can't fit it?
I have seen BG 323's with turbo'd kldes, and as i stated earlier you 3rd gen guys have ALOT more room to work with in your engine bays then us 1st gen guys.
and as far as intake manifold clearence, im not sure if a MX3 cylender would work?
what you could always do is get ahold of a 2.5l milenia intakefold.
its the curved neck style (MS8 style) klze manifold. it should fit no problem, and then sell ur strait neck ZE mani for a good $200
somebody really needs to do this.
im not sure how many of you guys have riddin in/driven a PGT/MX6 ls, but i have to say the V6 is much better then any turbo'd I4 IMO.
its so much smoother, and sounds way better.
oh yeah
you can turbo it too!!!
maybe when i pull out my DE and get the ZE in my mx6 we can try this on my bro's car. wouldn't that be sweet. the gang of V6 mazdas (sssh)
AND OMG LOOK AT MY BROTHERS CAR NOW!!!!!!!!!!!
WOOT!!! THOSE SEXY BLACK RIMS AND RED CALIPERS!!!! (freak)
sorry, that was my off topic ramble of the day
