3.0L SHO's were 5spds. 3.2L were automatics...3.4L were V8 automatcs... the SHO is a Duratec engine with heads, intake and ECU tuned by Yamaha. The engine blok is identical to all 3.0L enginesMikeBlueP5 said:I always thought the older SHO's had a 3.2 Yamaha engine, not a 3 liter duratec. The SHO 3.2 is bigger and different than the 3 liter, but you are correct the 2.5 and 3.0 are somewhat similar, the heads ( with slight work) will swap from the 3 liter to 2.5, ah i just ate my words, because the only 3.0 with DOHC would be in the SHO, and the other 3.0s are in the block cam iron. thats what i have in my ranger. But anyways the duratec i believe are iron block v6's because they started using them in the rangers in 95 or 96. I cant think of the name they gave the yamaha SHO engines.
Thapro1 said:^ is the tranny the whole problem with that setup? or is it also the wiring?
iirc when my bro's car and mine were side by side it looked like all the mounting points were the same...can't really remember tho it was awhile ago
well for starters you will need the whole underhood wiring harness. However, the Probe wiring harness that includes the fuse box runs through most of the front of the car and to the headlights and headlight motors. Since I know Proteges don't have headlight motors, some custom magic may need to be applied in many cases to get things to work.Thapro1 said:yeah thats what i figured.....ok so in short to make it work what would be needed....as far as the wiring goes? this is what has me stumped
well, this applied to more of the milennia problem. The transmission mounts weren't identical so you'd have to fabricate something. That's really about it though. Aside from your basic fabrication for the axles. I knew someone who did this swap in a 1st gen, but unfortuantely it doesn't apply for us.
__________________
anarchistchiken said:It would be easier to use an MX6 harness I would think. It's probably a lot closer to the protege then the PGT is.
Thapro1 said:oh ok ic....yeah i know the v6 basically bolts right in in 1st gen's and escort/tracers....actually thats what me and my bro are going to do after his ZE is put in the mx6...were going to sell his escort gt and get a wagon and put the usdm v6 in the wagon..lol
one other thing i was thinking of that might or might not be a problem was that our cars are distributorless and obd II while the mx6/pgt's have distributor's and are obd I
would this present a problem also.....wiring and engine's aren't my thing i know bodywork...lol
peace
dante
T4TURBO said:you need the motor mounts/axles/crossmember/shift linkage from a V6 MX3.
and there are OBII PGTs/MX6s. 96 and up are all OBDII. i dont know if that has anything to do with the distributorless ignition, kuz im not a 3rd gen guy.
don't see why the protege linkages wouldn't fit. The FS02 out of the Probes and the FSDE out of the Proteges have essentially the same manual tranny, and since the KL tranny and FS tranny have exactly the same length linkage, I don't see why it wouldn't work.
i kno it doesn't bolt right in i just didn't feel like explaing what all you need to fit it in a 1st gen as thats not relavent in this case......the V6 does not bolt right into the escort/protege/323
don't get smart nigga...lol
Thapro1 said:he's talking about a 1st gen protege
exactly.
