Waaaaaaay TMI, Peaches... gross.
Damn, my CWP with Tech Package was less than they're asking! Where's the moonroof?
who forgot clean underwear to change into after the lunch workout?
---> this guy <---
carry on
How many amps/volts are you getting at the starter? Perhaps there's an issue getting enough power to the starter so it doesn't have the strength to turn the motor past the compression stroke? Does the car have a manual transmission - can you turn the engine with the transmission in gear? That should tell you if it's something with the transmission.
She is gorgeous and was Playmate of the year on the first Playboy I ever found when I was 13
LOL!
On another note, my buddy just came home from deployment. Got him an s-plan pin for th cx5 h was planning on buying. S-plan price was 22,500 with incentives , he ended up buying for 20,100 out the door at a dealer out in Idaho.
LOL!
Yeah, if the engine is lubricated I'd think you should be able to turn the engine over using the wheels. Think roll-starting a car.You mean turn the wheel with it in first to see if the motor turns ok? I can try that, I'll have to get it up in the air again. As for voltage, I will try to check tonight, or sometime soon
She was pretty hot back then. Way too much plastic surgery now.She is gorgeous and was Playmate of the year on the first Playboy I ever found when I was 13
I fricking love that girl. Attack of the Show! used to be one of my fave shows back when I was a huge nerd.![]()
Naked yoga thats all I have to say
Did it come with a sack of potatoes? If not I say no deal.
I check before I go work out. If I don't have everything I need I go to McDonald's
