Sway Bar
davo
2002 Protege sedan 1.6ltr
Guys and gals of the site WERE can i get my sway bar from here in little old WA?????????? i have called so many people and no one has any idea about 323 2002 proteges here in wa :( any ideas??(dunno)
twilightprotege said:
whiteline.
they have a 20mm rear sway bar for the 323's.
or there is always america
They also have an adjustable 20mm bar as well. Part no. BFR59Z. The bar off a BJ does NOT fit on a BJII. Well you can get it on there (freak) if you try real hard like me, but it doesn't allow full wheel travel. (sad2)
But the adjustable on stiff setting is sublime as long as you stick to tarmac. It is a handful on dirt, a real handful YEAH!
so the bj bar doesnt fit the bjii? weird. i didnt know that
also sfc you've got the front sway bar, what mm is that?
Whatever stock 1.8 is. 24mm me thinks. Maybe that is why the power off oversteer is pronounced in the dirt! I think the SP comes with larger bars ex-factory doesn't it?
Yeah the bar arms are of completely differing geometry around the rear lower lateral link. You CAN get it in with a bit of de-barking and profane language but she clunks around going up driveways.
If you are going to add a larger rear sway bar please einforce the mounting tabs on the dampers . if you dont they may rip out of the damper tubes .
getting back on topic (if thats ok) ... i work for coles ... i cant give you any free stuff ... but i can show you how to drift a palet jack
Nice one. Pallet jack skating is so much fun, but I don't see how that is getting back on topic when this one is about Sway Bars!
back on topic??? ok i wanna buy the mazdaspeed sway bar set (25mm up front, 20mm in the rear)
if you are referring to the set from the mp3/msp i can get you a quote and shipping quote if you want
the mazdaspeed setup (like i said 25mm front, 20mm rear), fits the p5 fine i assume? also can you confirm it is 25mm front 20mm rear? thanks captain k
i can confirm that the 25mmFront/20mmRear is correct... I have the old Mazdaspeed accessories brochure right here in front of me :)
cool, thanks for that. the stock aussie p5 comes with 22mm up front and 15mm in the rear. for the aussies i just checked that at www.carsales.com.au so this will be a nice upgrade that's for sure.
captain k you have pm...well shortly anyway
