Lazy2.5
2015 Mazda 6 - AT - Tuned
- Ontario
What's involved in replacing the sway bar bushings on a CX-5? Do you need to remove the sway bar to access? I heard it's difficult, especially if corrosion is involved.
What about a control arm bushing? Is it difficult to press in a new one when dealing with corrosion? Or better to just replace the entire control arm once the ball joint starts to wear?
