No pictures in that thread btw.
Then there's where & how did the AWR break, autoX? manual clutch dumping stress? Bet it wasn't from daily driving nothing elseness.Thier used to be pictures in that thread when it was originally open. The AWR mount broke all the welds that held on the bottom peice where the bolts are.
However its the only AWR mount that I;ve heard of breaking but doesn't mean the others can't break as well. I also could of been a case of a bad weld on that one AWR mount.
I broke my AWR front MM under severe service during 40, 3 mile road course laps. After sending two quick pics to Tony, he sent me a brand new, stronger one free of charge (provided I return old one). Great SERVICE, thanks TONY!!!!
Yes I do agree.True but I'm sure that you will agree that any aftermarket mm should be able to stand up to any daily driving and extreme stress.
Yes I do remember reading that now that you reposted it. Exactly why I'm less than impressed with mine at this point with a sport auto daily driver no track time car & the other guy's front. Oem is staying on the side & oem with rr inserts going back up front. No problem with the other 2 oems so I'm gonna leave them alone until maaaaybe the SU set if my oems actually do give up & for now just enjoy the complete lack of vibration. Good deal coming in the FS section soon on a front & a side with replacement bracket. Somehow now, I really don't care whether they ever get a rear done cause I'm not wasting time or money on it. I'm sure they don't care whether I buy one or not & of course I don't care that they don't care that I don't care about spending any more of my money on their mounts.I posted the quote from the thread.
Interested in a gently used SLS front & passenger side? LOLMy AWR front mount has done the same thing.. its still on the car..just in two peices..lol
Looks like a bad design.
I never thought about it, but now that you point it out, it does look like most of the stress is transferred to the weld when the engine moves, and the entire thing sort of torques about the base. The stock mount had a design that distributed weight across the entire mount. We'll have to watch carefully if anyone else has this happen...Agree. Horrifying product is right. It looks like a sawed-off GM dogbone mount tacked onto piece of plate stock.
That would definitely help distribute the load and improve strength, but is the base wide enough to give both sufficient contact with the gussets and socket access to the bolts?I've had no problems with mine so far but it does make me look at it a little more and think about maybe adding some gusset plates to the side of the vertical tube for a bit more strength.........
