regular protege motor
Not to change subject but why do most places that build forged motor require you to use 20-50w oil? I thought the forged motors were built to tighter tolerances then the stock motors.
He was running 12-13 psi, he was bound to blow. His WGA is probably bad, ok not probably is bad.
I think that's just for break in so the rings expand well. I'd probably only run a 10-40 on my own car.
no it happen when i installed the bc. it was work good for like 2mon. the it would spike to 10 then 13psi
I have found out if a car runs exceptionally well all of a sudden some s*** is about to go down with it.
I've always said that myself, if it's running it's best it is about to blow. Neox has heard me say that a few times about my car. I've been thinking it's going to blow for a while.
