Problem solved
Scored main/rod bearings? Unfortunately, by the time any codes are thrown the oil has been contaminated for a while.
What codes were thrown?
It was definitely the pump gear. I scoped the upper motor and dropped the pan. Everything looks good. It wasn’t a hard stop and not metal on metal. Tension at the crank aligned with tension in the water pump gear.
