if it is behind the second cat then it is fine
it is there to chec the efficiency of the cat
you need to find out what code its stating
if your running real rich and the voltage clamp is sending an ok signal to the ecu under boost and the o2 is sensing cat efficiency low then it will trip a CEL that the cat is not working properly or that it is overloaded(too much fuel)
