Hey I just turboed my auto es. I have 89,000miles on the car. I got the ss afc. When I first had it installed I was throwing code po134 for no o2sensor activity. It was my wire connection for the afc. Fixed that and cel was gone. Two days later I get po131 low o2sensor voltage and po171 bank 1 to lean. I have a feeling it has to do with the o2 sensor circuit since both codes can be cause by having low voltage on the ciruit. So what do you think is causing the low voltage? Sensor crapped out, bad wiring again or afc?
