Bino: then its not VTEC at all. Monster cams have been around longer than VTEC has.
To get real big monster cams, custom billets are the way to go.
Variable valve timing is a completly different beast to variable cam profiles. VVT advances the cam timing dynamically as the revs raise (essentially doing what adjustable cam gears do, only doing it on the fly) - variable cam profiles actually shift the cams to a bigger set of lobes, providing increased lift and duration.
awesome... as u said, VTEC is not that special... i would have to get a standalone and HC pistons to run these cams efficiently, huh? and if we bore to let's say 2.3 (is that possible with FS-DE?), we would have to go to 230whp... would it be harder to hit that? or since it's still a FSDE it's going to be pretty hard to get up there...
Of course... to heck with that... just cut a window in your cam cover so you can set it for crazy power at the track, then change the timing back for the drive home.
sounds pretty ideal... change the timing with cam gears im assumin
now i'm just looking for shops in central or north florida... more likely Orlando, who will make some for me... pistons, rods, and cams... so if anybody knows of one, let me know...
and could u possibly tell me which of thses pistons would be best? options they gave me were: Forged, Teflon coated, Cast Aluminum,and Hypereutectic
Cam Options were: Stock, RV, High-Performance, Roller ... obviously high performance
and any tips and lingo for when i talk to them so i dont sound dumb or get tricked into something... what do i say? i want bigger lobes on the cams??
