I knew it was coming soon, but didn't expect it tonight....oh well, I needed to overhaul the trans anyway.
There were 4 ppl in the car and we did a pretty strong 2nd gear run...all of the sudden the engine starts bouncing off the rev limiter. Over the next 2 minutes the car would stop driving in gear. At first it would drive a little in gear, then stopped driving at all. I can just put the car in gear and let out the clutch without it stalling out. There were some mechanical sounds from the trans at first, but in the end it was like I am just revving it in neutral while in gear.
I'm just happy it's not the engine.
Have 48k miles on stock clutch an most of them at higher than stock power. Also did a full day of hard autox once.
Any suggestions?
I know I need a new clutch, might as well while I have the trans out. Should I just weld the stock LSD back together? I mean that'll be the cheapest route, and the stock LSD worked fine for me.
Thanks.
Any suggestions?
Thanks.
