Mike's 2018 CX-9 Signature
Watch out for the Coolant leak at cylinder head, it’s not a matter of if but when and it can catch fire
I'd appreciate it if you didn't spam this, or any other thread, with your unrelated comments. You've already started a thread about this, keep the discussion there so it doesn't detract from other topics. It will also be easier for you to keep track of replies if there are only one or two threads. Posting the same message in multiple threads is spamming, and those messages will be dealt with as such.
Further. while I can see that the CX-9 in the video you posted did catch fire, you have no evidence or proof to make a statement like "it's not a matter of if but when" and "it can catch fire". The video was posted without context, and lacking a lot of important information. It's good to be aware of it, but without more information or reports of the same issue, I find it more likely to be a one-off, highly unlikely situation. I'm going to post this same reply in the thread you started.
I too struggled to get the pads into the clips. Had to walk away, maybe why it's easy to get frustrated and get it in bent. Once it goes in it's clear that it's in.
Are you reusing the rotors, new pads?
Did you machine finish or just simple replacement?
Could you be experiencing some rust jacking of the caliper bracket metal under the clips? Do you replace the little metal clips or reuse the old ones?
My routine is pop the clips out, (mechanically) wire brush the bracket where the clips reside and then a light file to remove any remaining corrosion. Coat the fresh metal with some anti-seize or grease and install new clips (or your old ones if your kit doesn't supply new hardware)
I learned about rust jacking after struggling to get new pads into the brackets of a Ford focus many years ago.
You know, that's probably what it was, the rust jacking of the caliper on the surfaces that the clips rest on. I didn't wire brush or file down those surfaces. 🤦‍♂️ Thanks for the insight!
I reused the Powerstop rotors, and used the new pad clips and slide pin boots that the pads came with.
In an effort to keep the original brakes feeling nice, I've been disassembling brakes every 20,000 kms, cleaning, lubing, etc. It's pretty much required to do min once per year in Canada/rust belt or you greatly shorten the life. Will see how long they last, but original pads/rotors still look great at 60k
I will say the front pads on the CX-9 are a bit awkward to install, but what i'm doing now is taking off the bracket and starting the pads off the vehicle, then reinstalling. Seems an easier way to prevent getting grease on the friction surfaces by accident. Also gives me an opportunity to apply a thin layer of grease to all the metal/metal surfaces.
I've been using Pastelub for metal/metal surfaces, underneath the clips (to hopefully prevent rust-jacking), on the back of the pads, and super thin amount on the pad ears (i know this is debated, but if you're cleaning every year, then I think it is the better option). Nice to apply on hub/rotor surface also. Little goes a long way.
And for the caliper slide pins, I've been using Motorcraft XG3A Silicone Brake Lube for a while. This stuff has been a game changer. Similar to Sylglide, but it doesn't seem to ever break down.
It's possible. I usually metal brush wire with a drill attachment though, so unlikely.
I always use new clips.
Nice, are they as good as ppl say they are? I was on the fence as I have dedicated winter tires, and the cc2 looks like winter tires too. The highway and quiet driving and the additional grip is the selling point
Just wanted to confirm, these tires are fantastic! Road noise is nil, turning, braking, driving through wet rain feels very sturdy. No complaints. Oh, and the vibrations are reduced significantly.
Car and driver did a good review of them here:
What I liked in the review is that it is the first time that i see a review that compares all-weather tire to dedicated summer tire and dedicated winter tires (scroll to the end of the review). Because they are often the best in reviews in their own category, but i was always questioning how they performed compared to dedicated winter tires. Now the only thing i don’t know for sure is how they compare to all-season tires, (like the well loved on this forum pirelli AS3 plus )
I never had that problem except the last 2 times I installed pads which were Akebono. The first went into the front of my wife's Scion. I thought, what the heck, must be a fluke set, had to file them down a bit to get them to fit. The second set went into the back of my CX5, and they were a real bear to get in, had to actually grind off about a 1/16 of an inch to get them in and I'm not happy about how they went in, now I'm thinking no more Akebono for me. I put a set in the front a few years ago and they went in fine. I walked away quite a few times for that last installation.
Huh. The OEMs are Akebono, as well as the ProACT ceramics I installed. Both were identical in shape and size and I didn't have any issues installing them. My CX-5 Turbo shares the front brakes with the CX-9 (and I doubt that rears differ much, many parts are shared to save on costs).
It was quiet for a while, but I've got a new issue. Hopefully I'm on the right track to get it resolved though.
Over the weekend, the car's engine temp readout was showing higher than usual. Normally its right at 90 degrees and stays there when the engine is at normal operating temp, but it started climbing higher and higher. I noticed that at one point, if I had been driving the car for about 10 mins or so, and came to a stop in traffic, the temp readout would climb high enough (over 120 degrees) that the red engine temp warning light would start to flash on and off. It never went into the red, and it never climbed higher than that. Additionally, once I started moving again and accelerating, the temp readout would quickly drop back down to 90 by the time I reached 50 km/hr.
I've been keeping an eye on my coolant level, and it's remained consistent. No visible coolant leaks or smells. I don't think it's the thermostat because the upper coolant hose is hot when the engine is warmed up, the engine temp hasn't actually gone into the red, and I don't have a CEL. I think that the issue may be a faulty engine temperature sensor (Part number SH0118840). As a side note, I've been noticing that the car sometimes cranks longer than it normally does. Originally I thought it might be spark plugs or the battery going out, but it seems that the faulty sensor can also cause long cranks. Just to be safe, I decided to order both the sensor and the thermostat and replace both.
It turns out that the Mazda OEM replacements for both the temp sensor and the thermostat are only about $20 higher than the cheaper aftermarket alternatives from RockAuto, so I went with OEM this time ($104 vs $86). Parts should be available for pickup by Friday, so hopefully I'll have this resolved this weekend.
