Hey I’m looking for a manual transmission swap if anyone knows someone selling one. My automatic transmission is going out.
I don't want to be off-putting, but to be completely honest, I don't know that you're going to get a lot of help on here with a project like that. With these cars being as old and relatively cheap as they are, I would think that most people would just buy a factory manual.Hey I’m looking for a manual transmission swap if anyone knows someone selling one. My automatic transmission is going out.
Yeah I was looking to buy one, I just did now I just need to find a few more parts for the transmission I’ll check the sale section. Thank you.I don't want to be off-putting, but to be completely honest, I don't know that you're going to get a lot of help on here with a project like that. With these cars being as old and relatively cheap as they are, I would think that most people would just buy a factory manual.
With that said, I'm certain that it is both possible and has been done and documented by someone in the past on here. Dig around and see what you can find, and let us know how it goes.
Edit: I realize I may be misreading your post. If you're asking about purchasing a manual trans, then you probably have the other stuff at least somewhat figured out (or you're willing to take the gamble). The WTB and For sale sections on here are a good place to look/post. Good luck!
Thank you. I just started tearing it all apart the engine and transmission came with the ecu thankfully. But I need just the rear mount and the other one connected straight to the trans right?If beyond the transmission your P5 is in otherwise good shape, it makes sense to convert it from an automatic to manual. I enjoy driving my P5 more than my ND Miata, and that's down to the manual transmission. You'll need a new ECU or a re-flash of your current ECU as you already probably know.
The differences between engine mounts for automatic and manual P5's has been discussed a lot on this forum (with good reason), and you may have to buy one or two new mounts as well.
Thank you I’ll do some research and find out what I need to do.Well, that's the weird part. The engine mount on the *passenger* side is supposedly different between the manual and automatic transmissions. Please do search this forum for discussion on that and hopefully others will jump in on this thread. If I recall correctly, most of the Amazon/whatever kits containing four mounts are made for automatics. I've replaced three of my four mounts with Mazda OEM mounts as I didn't want to revisit them only a few years later. They're probably the most valuable part of my car at this point.![]()
Easy, I just went to the Mazda dealer and gave them money.Thank you I’ll do some research and find out what I need to do.that’s crazy how did you find the Mazda oem ones
