Yes it did. The only problem was the slight bump i faced during the first start in the morning which i now suspect was due to a low fluid level.Understood. Did the car shift fine when you first got it?
Got it. So the shifting pattern reset and fluid topping off both helped.Yes it did. The only problem was the slight bump i faced during the first start in the morning which i now suspect was due to a low fluid level.
