Like the title says I installed an Injen cold air this morning. Everything else is stock under the hood. Definitely can hear the spool alot louder which is nice but seems to have what Ive read to be the "turkey flutter" when you shift. Not sure if its actually the flutter but I wasnt under the impression that the bpv was that loud. Hard piping ETS sidemount are on the way and Im gonna run the dual setup with a Greddy RZ so just seeing if this is something I should be worried about? or if maybe running the dual setup will eliminate it?
