How high is max boost in cold temperatures?
OH MY GOD!
Some one in ohio done did a NAMEJACK!
Now this is a sad day!
Matt:mad:
I don't get any spike from the stock boost. It peaks at 7psi at around ~2800 RPMS, and slowly drops off to around 5psi at redline.
I don't get any spike from the stock boost. It peaks at 7psi at around ~2800 RPMS, and slowly drops off to around 5psi at redline.\
When the car is cold or intake air cold
sounds about right.
Your gauge could just read little low.
Matt
I don't hit boost until the car is warmed up. The results are the same for me regardless of temperature: 7psi peak, falling to 5psi at redline.
New Threads
