7
70
Nice!TurfBurn said:i also ordered components to make two more spool controls so that I can finish that testing and get those out as well. Those shouldn't be far behind...
then I also have an fuel cut eliminator/MAF signal conditioner that the first proto is out and will be tested shortly and will soon be available... then I have an O2 thing in the works that will let you adjust fuel mixture a little bit.. on stock vehiclesand then a possible adjustable MAF modifier that will give you some fuel adjustment capability and then after that I have some brake cooling ducts that I'll be working on... and a few other things....
But, get the first things done right first. Then move on from there.
Let me know when you have it all together.
