GI: MBC with creep protection and spool up control
TurfBurn said:
Ahh... I misunderstood you, I thought the spool controller (based on your pm) was the problem, not that turbo.... I was concerned at that point! But I understand what you are saying now. If there is anything I can do to help just let me know!
Thanks,
Steve
Sorry man, it was my car before the unit was on. I will get it taken care of and then go ahead with the spool controller. Just to make sure it's clear, the spool controller did NOTHING to contribute to my issue, it was already there before the unit was on and is still there with the unit taken out!
I am interested. Im just moving some stuff here and there, gathering some $ for the forged stuff. Give me a few days. I just want to boost controller...do you have pics of the boost controller alone/?
TurfBurn said:
Bump for interest and updates! :)
I verified that my wastegate is good, so now I am in the process of getting a vacuum distribution block to go inline of the brake booster. It may be a couple of weeks, but I may rig something up until then.
Yep pictures of everything are in the products section on our webpage... www.nsnmotorsports.com!
Hope that helps!
Thanks,
Steve
Hey turfburn, is it still possible to get a spool controller from you? Will it work and will it help at stock boost? I think you wrote somewhere that it blocks the signal until 5psi, can this level be adjusted?
I couldn't find it on your website, but then again it says under construction now.
Recieved it. The black tip goes on the wastegate side and the white tip goes to the manifold? Is that right?
Yep... that is correct. Install it that way and start out with it screwed mostly apart... then just keep screwing the halves together until you get the response you want. If you put it too far together you will get boost spikes and some odd behaviors like that... let me know if anything comes up!
Later,
Steve
