- 02 1500 4x4, mp3
alright i need your help....i am debating on wether to get aux fuel pump and protege 5 ecu swap or just get hiboost ecu or perfworks piggyback....anyone like to share their opinions........
dominoy2k1 said:alright i need your help....i am debating on wether to get aux fuel pump and protege 5 ecu swap or just get hiboost ecu or perfworks piggyback....anyone like to share their opinions........
dominoy2k1 said:so the miata pump will work better than the stock protege one?...damn i am off to find some money....let me check the "tree"....
PS thanks alot....
twilightprotege said:if you get the 255lph HP intake pump, you'll never need to touch your fuel system from the engine back ever again
DooMer_MP3 said:If you're thinking about dishing the money out for a true solution, I would either get HiBoosts Haltech and do it right, or wait a little longer for perfworks' piggyback so you can control fuel AND timing.
Chris
GOTZOOM? said:
The pump is not used to control fuel, it there to make sure you get enough fuel when its needed.
