Ground to fender measurements?
teddymac
'21 CE-T
'21 CX-5 CE-T
What are your ground to fender measurements?
With 225/55 r19's, CS springs and Bilstein Shocks mine is as follows.
Front 29.375
Rear 30.25
As measured vertically aligned with the center caps of the wheels.
Front
Rear
Visual
Curious what others are at, even stock suspension.
stock 2023 cx5turbo
driver side F 31.8125 R 32.375
pass side F 31.875 R 32.5
so you look like you dropped a couple inches+at least compared to mine...
Corksport Springs
OEM Dampers
245/45/20, full tread
Inches (cm)
FL 29 3/16 (74.14)
FR 29 1/16 (73.82)
RL 30 1/16 (76.35)
RR 30 5/16 (76.99)
Yeah that is curious. I can understand the front left being a little higher to account for driver loading, but I'm not sure why the back is uneven in the opposite direction.
sit in the driver's seat and have someone take measurements and then have a passenger get in and take more measurements....in reality coil sag over time and just the fact that these really are not precision made items would account for slight differences. these kind of things have tolerances. put several 1000's miles on and measure again and see where you are at.
My OCD is kicking in on this!
As I follow and watch other CX5's drive around my area, I've noticed that the angle of the right rear lower control arm is steeper than the left as well. I wonder if it's something funky with the geometry of the rear suspension causing this... Or maybe it's just that the body wasn't designed symmetrical with the kodo design method, haha.
or, maybe it's time for me to get coilovers and even it all out manually.
As soon as I have the cash, that is what I plan on doing. But not because of that.
