fuel pressure gauge...
DiS
In Soviet Russia...
Contributor
2016 Subaru WRX Crystal White Pearl
Got a question for all of you who have aftermarket turbo kits...
I've boosted my car 2 Fridays ago and for fuel management I am just running BEGi rrFpr along with fm clamp...now I bought it like almost 2 years ago and had no directions to accompany it...
Question is, where on the feed line does the fuel pressure guage have to be mounted at? I think it has to be the last thing on the fuel feed line before stock fuel pressure regulator, right? Right now I have it on the on the feed Tee line off of the main line (guage is between BEGi and Tee on main feed line)
So after I started reading 34 PSI on the guage (at idle) I have started to adjust BEGi (0 vac. point....vac. line is off the BEGi) (the top screw is all the way in and guage still reads 34 PSI)...Now I guess thats only BEGi's output pressure, and correct me if I'm wrong, but in order for me to tune BEGi the correct way, I have to have fuel pressure guage as I have described above to get combined pressure of the stock fuel pump and BEGi?
P.S. I know that BEGi is working because when I turn the top screw counterclockwise, car runs like s*** (leans out), and when I have the screw on BEGi turned all the way in (not sure if its all the way in, but its snug....don't wanna break it...) car runs fine (14.7 AFR's)
sure, I'll post a pic tomorrow (don't have any pics of fuel pres. guage in particular yet)
I have a gauge on my fuel line Ill try to get a pic. Both fuel lines come up along firewal under the brake booster, the one that runs up over the trans and curves by the intake piping is the feed or presure, the one from the regulator back down is the return. dont tap in to return line for your gauge I made a new feed line with a fitting for my gauge, cheap summit gauge hooks to it.
The fuel press gauge must be installed Before the fuel rail and the RRFPR should be After the stock FPR (or in the return line).
Which side is of the fuel rail will the begi need to be tapped into? the passenger or the driver side? I am confused which is the fuel input and which is the return line.
