Can an awr pan be modified to accommodate this gate system? I wish the ext prv setup was available when I swapped in my motor. Still have some topend work to do in the future so when the time comes this is definely on the list.
Don't get me wrong...the AWR pan is very good for what it was intended for. It does have a variation on the theme of the gates with the directional tabs. However, if you are expecting some real movement of the oil in the pan there is nothing around the bottom of the pan where the head of the pickup sits. Due to the nature of the AWR pan with the upper plate welded in it looks like it might be quite a lot of work to add a gated system. I think it might be easier (and less expensive) to have a pan fabbed like the one we use. (just my 2 cents)
