Mazda2 DE 1.3L ZJ-VE Engine Disassembly
OZCorolla_x
Swiftly
2009 MAZDA2 NEO 1.5lt Auto 5Door JMODE10Y1901426XXX. 203,500km
Had been looking for a MAZDA 2 DE 1_5lt MZR ZY-VE Engine Disassembly Video
MAZDA2 ZY-VE 1_5lt Engine CutAway
Found this one for a MAZDA 2 DE 1.3lt ZJ-VE
youtube.com/watch?v=ihZ3cNHjOl0
Successful Mazda 1.3 MZR engine (ZJ-VE). Why aren't all motors so reliable? Subtitles!
Jan 23, 2021
& its video/picture quality is good. :)
...Republic of Belarus so subtitles & the "Transcript English Auto generated text" is not perfect...
If you have the MAZDA 2 DE 1_5lt MZR ZY-VE Engine Workshop Manual, it is VERY Useful
Start watching at:
@1:06 1.3lt MZR (ZJ-VE) - discusses rough idle
@3:27 Engine Disassembly Commences
Made a few Notes that should help:
@3:27 1.3lt MZR (ZJ-VE) Engine Disassembly Commences
- Super-locksmith Nikolai will help us quickly scatter this motor….:ROFLMAO:
The intensity on the face @3:32 is amusing
@3:44 Drive By Wire Electronic Throttle Body Unbolted
@3:45 Throttle Body Silicon Gasket?
@3:48 Drive By Wire Electronic Throttle Body in DISPLAY TRAY
@3:53 The Throttle Body has Engine Coolant pass through.
NOTED: You don’t need to remove the Throttle Body from the Car to Clean the PCV Oil Vapour Residue Gunk From the Throttle Body Internals as part of trying to improve the Engine Idle Stability/engine shaking problem. Just unbolt it & leave the coolant lines attached, & position it so you can clean both sides & the throttle plate.
@4:02 Unbolting the Fuel Rail
@4:05 Fuel Rail & Injectors Out/Removed
@4:09 Fuel Rail in DISPLAY TRAY
@4:10 Close up of Fuel Rail & Injectors Tip Rubber Seals that you replace as part of trying to improve/rectify Idle Stability/idle Wander & since you have to take the Fuel Rail & Injectors out to replace the Inlet Manifold Gaskets you just replace them while they are out.
@4:16 Inlet Manifold Unbolt
@4:24 Inlet Manifold Removal
@4:25 looks like the Inlet Runner Vanes are internal to the Runner makes removal easy
@4:28 Intake Manifold on the DISPLAY TRAY - In the Intake Manifold of the MAZDA 2 ZJ Engine there are turbulence system (VTCS) Dampers,
@4:37 on the 1.5lt ZY-VE there is also a mechanism for changing the length of the intake manifold
@4:39 The Turbulence Dampers are driven by an electric motor & almost never require attention - Moves the Vanes back & Forth
@4:41 The Plastic Inlet Manifold to Cylinder Head Silicon Gaskets are visible & look distorted probably lost elasticity ie replace them
@4:45 It should be noted that Longitudinal Play does not occur (its a metal rod) BUT Axial Play of dampers may occur & this will cause the intake manifold to Click or Tap when Idling.
@4:51 Close up of The Plastic Inlet Manifold to Cylinder Head "Silicon Gasket"
@4:56 This malfunction can be eliminated by placing washers under the damper axle gear on the motor side
@5:02 The Mazda 1.3lt MZR engine is equipped with an EGR Valve. (On the rear LHS Top of the Engine 2 bolts to remove it)
It is an electronic valve with a stepper motor. This is structurally reliable but it has no feedback to the ECU.
If the EGR valve stem wedges in the slightly open position the ECU will not see it in any way & the motor can receive exhaust gases immediately after starting. Best to use a Low NOACK Oil.
@5:22 From here, you get problems with idling, low power may appear & the engine may simply not start. Therefore it is worthwhile to clean this valve every few years and at the same time check the conditions of the stepper motor windings.
@5:38 Resistance between the centre and adjacent outer pins should be 20 to 24 Ohms
The EGR Valve has Engine Coolant through it to help stop Oil Evaporating to form VARNISH & gumming up the EGR Valve (best to use a Low NOACK Oil) & also to stop hot exhaust gases damaging the electric stepper motor windings. The Coolant Change Bleed Nipple is attached to the Engine EGR Valve coolant inlet tube
@5:45 Remove Coil on Plug Packs
@5:49 The Mazda 2 ZJ engine is sensitive to the condition of the spark plugs.
@5:54 Due to wear of the electrode, the engine starts poorly, idles unstably & consumes more fuel
@6:02 Coil on Plugs in Display Tray. The Ignition Coils, however serve very well.
@6:05 Plastic Thermostat Housing Removal
@6:10 Cam Cover Unbolting
@ 5:15 Cam Cover Removal shows the Perimeter Gasket, the Spark Plug Tube seals are integrated as part of the Perimeter Gasket. Underside of Cam Cover has no Varnish, looks very clean
@6:20 The life of the Cam Cover Gasket is very decent - this engine does not annoy with oil leaks from this seal.
@6:30 When removing the valve cover to check or adjust the thermal clearance of the valves, replace the Gasket, the old one will have lost some of its elasticity
@6:41 Timing Chain & Cams look clean. Single SVVT on the Intake Cam
The Valve Actuator (Cam Shaft) has poppet tappets (Buckets) without hydraulic compensators so the thermal clearances need to be checked regularly.
@6:49 The MAZDA instructions state that thermal clearances should be checked for noise every 45,000km.
@6:57 If the MAZDA ZJ engine clinks/rattles suspiciously then valve thermal clearances should be measured more closely.
@7:05 In Practice the Motor runs to 200,000km (or more) without problems, without needing to adjust the valve clearances.
@7:12 There have not yet been any cases of exhaust valve burnout due to the increased clearance
@7:17 Adjusting the Thermal Clearances in this engine is both inconvenient & labour intensive you need to swap out the Buckets that Push directly on the Valves Stems
@7:21 There are 35 sizes of Bucket Pushers according to their thickness.
@7:31 The nominal clearances are 0.3mm +/1 0.03mm each for the intake & exhaust Valves
@7:39 MAZDA Engines can suffer from failure of the Knock Sensor located in behind the plastic intake manifold, just above the PCV Valve Baffle enclosure.
Its malfunction is identified by an ECU OBDII MIL Error Code.
@7:49 A good knock sensor should have a resistance of about 560kOhms +/- 30kOhms
@7:54 Removes the Crank Pulley Bolt & then the Timing Chain Cover Bolts
@8:06 Water Pump Off
@8:16 Removes the SVVT Oil Control Solenoid Valve
@8:17 Timing Chain Cover Being Removed
@8:20 the SVVT Oil Control Solenoid Valve “Oil Screen Filter” that is accessed by removing the Accessories Belt Idler Pulley
The Engine LOOKS VERY CLEAN INSIDE
Top of Timing Chain Cover above the SVVT Oil Control Solenoid Valve Hole the “3 Small Holes Oil Passages Gasket Seal” looks deteriorated
@8:22 Timing Chan Cover Crank Pass Through Main Oil Seal
@8:27 Mazda 2 has 5 Petrol Engines, two motors of 1.3 & 1.5lt are of "Japanese origin & are equipped with a timing chain drive".
The Other gasoline engines are Ford units that have a timing belt drive with a toothed belt.
@8:32 Timing Chain Polymer Guide that the Timing Chain Tensioner pushes onto.
& the ORing that seals the Oil Pass through from the Oil Pump via the Timing Chain Cover into the Block Oil Gallery
@8:33 Timing Chain Tensioner with installation hook latch visible pushing on the Timing Chain Polymer Guide. PROBLEM is the two bolts to remove the Timing Chain Tensioner are inside the Timing Chain Cover. So you need to remove the Small Inset Cover/Hatch to access it if you don’t want to take the Timing Chain Cover Off
@8:33 Oil Pump housing bolts
@8:37 The timing chain on the 1.3lt ZJ Engine is the same as on the 1.6lt Z6 engine.
This is a Morse Plate Chain. It serves perfectly on MAZDA engines, it is unlikely to fail. Expect 250,000 to 300,000km life.
@8:52 Replacing the timing chain on this motor does not require any special tools or clamps.
@9:00 Replacement performed when the piston of the first cylinder is set to top dead centre, all the necessary marks are present on the crankshaft and camshaft pulleys
@9:07 end on shot of the SVVT Intaake CAM Gear, 4 STAR Torquex Bolts, to open the SVVT Gear
@9:10 On this engine the Timing Drive is in excellent condition
@9:14 The Chain is tensioned & the Tensioner is extended to a minimum
If we talk about the condition of the camshafts, everything is like new
@9:22 You have a question: Why are we disassembling this Motor? Because this motor is not in demand in Republic of Belarus/Russia. MAZDA Cars in our countries mainly drive with Ford Engines (?implies given comments above @8:27 the engines in Republic of Belarus/Russia have Timing Belts).
See what wonderful motors come to us from Europe:ROFLMAO:
=>> Implies car was serviced regularly with FULL Synthetic High Quality Oil?
@9:36 The Intake camshaft phase regulator of the MAZDA ZJ engine, as a rule, lasts a very long time without problems. Errors in the variable valve timing system or morning rumble after starting are rare for this engine
@9:50 holds up the SVVT Oil Control Solenoid Valve..Suggesting that it is reliable & no evidence of Oil varnishing or other buildup or Electrical Coil Failure.
@9:57 Removes Timing Chain Tensioner
@9:59 Timing Chain Removed
Look Timing Chain sag is minimal here
@10:04 The Cylinder Head of this engine serves perfectly. There are no problems
@10:07 Unbolts then Removes the Oil Pump
@10:08 shows inside Oil Pump = Very Clean
@10:09 Starts Unbolting Cam Bearing Caps
@10:09 Starts removing Cam Bearing Caps
@10:23 Removes Intake Cam
@10:24 Removes Exhaust Cam
@10:25 Starts Unbolting the Head
@10:33 Head Lifted Off the Block
@ 10:35 Clear view of the Underside of the Head on the Display Table
Intake Valves Clean (its port injected)
Exhaust valve black
"Water Jacket pass through the Block Locations V’s Cylinder Wall Clearance" looks Ok
This is some of the BEST Video I have seen of this during disassembly & something I was looking for
@10:40 There are no carbon deposits in the combustion chambers
“Spark Plug Tips” Look White?
The only thing is that there is a small deposit on the periphery of the piston.
@10:49 The Cylinder Block of this engine is Light-Alloy with "Chill Fit Cast-Iron Liner Sleeves", an open cooling jacket.
You can see the Valve Clearance recesses in the piston crowns & they look reasonably clean.
Water jacket is open
In terms of condition the surface of the cylinders bore...is as good as new.
@11:06. But there are carbon deposits on the periphery of the pistons.
?Well by tradition, we will tell you what kind of oil is suitable? Seems this is something they do
@11:10 Unbolting the Sump
@11:18 Sump Removed. Not a Gasket just silicon gasket maker (comes from the factory)
@11:21 Unbolt the PLASTIC Oil Pickup Strainer
@11:24 Unbolt the Crank Retainer Block Housing
@ 11:37 Crank Retainer Block Housing Removed
@ 11:39 Undoing Piston Conrod Bearing Caps
@11:44 Pushing the Pistons Out
@11:52 Lift the Crank Out
@11:53 DISPLAY TABLE Pistons, Crank & Crank Retainer Block Housing
@12:01 An Engine Oil Sales so pitch skip thru to 12:29
@12:29 BACK to the Engine disassembly discussion
The engine never ceases to delight us.
@12:32 & 12:33 The main bearings are without wear.
@12:34 to 12:36 The Connecting Rod Bearings are also without wear
@12:37 to 12:42 The CrankShaft Bearing Surfaces look great.
@ 12:43 to 12:48 Three Piston Rings - 2 Compression Rings & 1 Oil Scraper Ring
What is very important, the Oil scraper Rings are clean
A little varnishing between the rings on the side of the pistons
A little combustion byproduct down the side of the Piston Head towards the first compression ring.
@12:49 But the only question that arises for us is where did this small soot on the head belt come from? (ie the combustion byproducts on the side of the Piston above the 1st Compression Ring
@12:52 The design of the pistons also pleases us, yes the Pistons have a T Shaped profile, BUT the Piston Skirts are slightly Longer.
?Should stop Piston Slap?
@13:05 Each Piston has six holes drilled to drain oil from behind the Scraper Rings & there are recesses under the oil scraper rings
@13:10 Mazda ZJ engine oil consumption is not inherent or common.
@13:13 to 13:24 However, Oil scraper rings can loose their mobility due to operation on poor-quality Oil. (Use high quality Full Synthetic LOW NOACK Oil <6%)
In this case the engine will consume more than a litre of oil per 1,000km. There are not many such cases.
@13:26 When Oil scraper rings are stuck/gummed up, decarbonization hardly helps. We’ll have to remove the pistons & change the piston rings.
@13:32 to 13:38 Looking @ the Crank Block Big End Bearings & down the Cylinder Bore
Oil Feeder Pipes visible to Cylinder 2 & 3’s Crank Bearings
The Upper Crank Bearings are also in excellent condition
@13:41 to 13:43 There are oil spray nozzles in the cylinder block for underside of pistons & cylinder bore walls
@13:44 Disassembly is complete & today we have disassembled an exemplary reliable Japanese Motor.
Hope the above helps someone/is of interest.
Rob
Excellent video.
I've got the US version 2011 1.5 ZY-VE engine, and the video mentions variable length intake runners for the 1.5. I've got the manifold off right now for a good cleaning and to replace gaskets, but I don't find this feature in my engine. I have the turbulence damper assembly, but I would assume that variable length runners would require some sort of actuation assembly, such as the motor that drives the turbulence dampers.
Can anyone with a 1.5 point me at the mechanism for variable length intake runners?
Toyotas used ACIS or earlier TVIS System with a set of vacuum actuated Butterfly Valves.
MAZDA seems to use "VLIM"
....the "Inlet Manifold Flap" shown in the "Cut-Away" looks like the MAZDA 2 DE 1_5lt MZR ZY-VE Engine "Intake Lengthener"
But somewhat Oddly.....the "Intake Lengthener" Control Method does not appear to be separately identified on the ECM Inputs/Outputs in my MAZDA W/Shop Manuals per:
2014_01_29 WORKSHOP MANUAL MAZDA 2 DE 3782Pgs
Pg2525 to 2527 only lists
2011 - Mazda2 - Engine VARIABLE TUMBLE SHUTTER VALVE ACTUATOR REMOVAL/INSTALLATION [MZR l.5]
( Noted the diagrams & info in my .pdf manual are pretty much the same as this Intake Air System
ma2auto.com/intake_air_system-1089.html )
nor the
2013 Mazda SUPPLEMENTARY MANUAL 1509Pgs
Pg1390 to 1392 only lists
VARIABLE TUMBLE SHUTTER VALVE ACTUATOR REMOVAL/INSTALLATION [MZR 1.5]
nor the
001 MZR 1.5 Engine Workshop Manual 2010_05 P_N 9999–95–MZR–11 70Pgs [which does not detail the intake manifold at all]
Per:
1.5lt ZY-VE Variable Length Intake Manifold
australiancar.reviews/mazda-zy-ve-engine/
"Variable Induction System (VIS)
For the Mazda DE Mazda2, the 1.5lt ZY-VE engine had a variable length intake manifold that was referred to by Mazda as a variable induction system or VIS. At low engine speeds, the intake runners would have a longer path to increase the pulsing effect of the airflow and draw more air into the cylinder. At higher engine speeds, however, a valve would open to shorten the length of the intake runners, reduce intake resistance and allow a greater volume of air into the cylinder for top-end power."
(In Australia we only rec'd the 1.5lt ZY-VE engine, no 1.3lt ZJ-VE SFAIAA, there was a BUDGET 3 door version, but think that still had the 1.5lt ZY-VE)
LF8218741 Vacuum Runner Solenoid Valve for Mazda vehicles (3, 5, 6, CX-7, typically 2004-2013) that regulates the engine's intake manifold runner.
I'll have a bit of a look at the Intake Manifold when I'm next working on things. Expect there is an actuator for the "Intake Lengthener shaft" hidden down low on Intake Manifold Runners
Rob
Thanks for your reply, Rob. I feel like maybe it was a feature on the ZL-VE, or some other variant that we didn't see here in the US. I've heard it referenced a time or two in other places, but I don't find evidence that it actually made it into production. I've even explored euro and asia parts diagrams and not found any clues.
The system diagram above matches what I found when I had everything apart. The only thing not shown there is the brake booster vacuum line, which plugs into the manifold right next to the PCV and MAP lines. There is a small rubber plug on the throttle side of the manifold, down low. Referenced as 13-104J in this diagram.
Maybe that was for a feature not implemented?
-Mark
Ok, mine has what I think is the "..Inlet Manifold Length Adjustment "Pivot Rod".." visible on the LHS of the Inlet Manifold, at the nominal location where the cutaway above shows the "..Flap & the "Pivot Rod"..".
I have the hacksaw blade touching what I think is the end of the "..Inlet Manifold Length Adjustment "Pivot Rod".." in the picture below.
I'll put the endoscope camera down the other side of the inlet Manifold when I have a chance.
Fig: "..Inlet Manifold Length Adjustment "Pivot Rod".." LHS of the Inlet Manifold.
Rob
