I see, the analog in hit 5.06v, but the analog out never went about 4.98 so it is doing what is supposed to be doing. So I don't know what it is. I see the AFR goin way rich, maybe you are blowing the spark out by being so rcih. Do you have a WBO2 to tell the AFR when the SW shoots it pegged rich? What gap are you running on the plugs?
Also, do you idle in the first column or the 2nd? If you idle in the 2nd, you need to change the deflection to get it in the first column. I can tell you how tomorrow when you call.
