emptystrings
This is sort of shopping list of questions. Any educated responses are much appreciated. Thanks!
1. Speaker location: I want to put the rounds (6" or 6.5") in the front doors and the longs (5x7" or 6x8") in the rear doors. Has anybody done this or know if this configuration will fly with the use of some adapter mounts?
2. Trunk floor: From what I've seen, most amps are about 2.5" high, so I'm thinking about raising part or all of my trunk floor up 3". Most people on the boards seem to be using MDF for the new floor. What goes underneath the MDF to raise it? (2b. I have access to very limited amount of tools. What would be best way for me to get my MDF shaped in my situation?)
3. Screw locations: are there any places in the trunk I should NOT try to put any screw holes?
4. Amp heat: Should I worry about heat dissipation? I've seen installs where the amp is enclosed behind plexi, so I assume it's not much of an issue, but I wanted to see what people had to say about it.
5. Factory sub: any way to get more sound out of its 100W? I don't want to lose any more trunk space, and I don't feel the need to get a whole lot more bass. Just thought I'd ask and see if people have tried anything with it.
Thanks again guys. Some of the installs on this board are light out nice. Pretty inspirational if you ask me.
