turboge said:This is a good example of what I was talking about.
You can see between 2000-4000 the ecu fighting the changes. The programming hits the desired ratio then the ECU compensates because it knows that it cannot be in OPEN LOOP at that particular moment.
With the FMU on there it impossible to see the actual results of the system on the car. But nonetheless I think you're making progress. Hope it pans out with larger injectors.
My daughter gave me that, why dont you go smell your ballsraku said:did ne one mention his steering wheel cover...cheetah print hahah.
orangezoom said:My daughter gave me that, why dont you go smell your balls
Nope, Much better.shaolin said:haltech? No?
