Agape_365
2019 CX-9 GT AH edition, 2009 Suzuki Swift
If your refering to stole, clarifying borrowed neighbours and friends cars to test.Wait, what?
Ok, alot of information in this thread if its newer then 2017 it will not let you wind your turbo up let alone your engine if its 2 cold out it will basically start screaming at you "flashing light and a beeper going off" you will know it gives u a mini heartattack "ask me how i know" as it does it and then regulates you.
This is the same across cx5 and cx9 stole 5 other cars of different model years and tried it scared myself each time. Basically wont let you do anything till out of the blue zone if to cold
You borrowed/stole your friend's and/or neighbor's cars and proceeded to thrash them before they warmed up? Did they know this?
Remind me to never lend you a vehicle!!!![]()
Well said!X2 @Snorting2.5
In another world, 5.9 Cummins Turbo Diesels, my CTD has 265,000 miles on the original engine/turbo. Still pulls a +10,000 pound toy box all over the country.
Until recently, I never did anything special to warm up the engine/trans. I didn't beat on it either until warmed up.
Some of us diesel geeks are messing around getting better fuel efficiency for our old CTDs. This winter I've been plugging in the block heater and added two oil pan heaters. I run the heaters from 1 to 2 hours before driving. The engine cranks effortlessly and heats up within in 2 miles. We have increase our fuel mileage 30% by adding some bolt on items and changing our driving habits.
The Cummins also has a winter cover and exhaust brake. Both of these accelerate the warm up process.
These Mazda gas burners warm up quickly when under a light load, driving. I see no reason to do anything special. Drive it with respect and it will respect you in my moto.
I read on this forum about keeping the RPM down. I found out the hard way many years ago when I kept my Chevy truck below 1500 RPM. It spun a bearing at 90,000 miles. We put a new engine in it and drove it to 250,000 miles. Didn't lug it nor over rev it.
We keep the CTDs in the sweet spot, 1500 to 2000 RPM and don't think about it. It will see +2500 when towing and merging. My plan on the 2024 2.5T, keep the RPMs in the sweet spot, 1500 to 2500 RPM and enjoy. Every so often 4000K that is well within the design range.
Keeping clean fluids, replace filters often and be happy!
We added exhaust and turbo blankets to our CTDs and have seen a nice gain in HP and FE. Equally important, it lowers EGT. This is counter intuitive. The link below explains why.Well said!
According to my data logging, the "desired RPM" is 600rpm....
So, the AT seems to help maintain engine RPM's as close to there without lugging, while actually sustaining some sort of momentum... around 1250rpm...
I find that the AT will shift at whatever rpm it takes to hit around 1250rpm (or less) in the next gear. It will hold that gear until a hair over 1000rpm before it decides to downshift.
So, usually, I abide by its wishes and stay between 1250-1750rpm.
I'm investigating adding a turbo blanket to the CX 5 in the near future.
An engineering student tested a turbo/exhaust blanket one a 6.7 CTD. It's an interesting read. The cliff notes, the blankets saw a HP/Torque increase 10% in the lower RPM range.
If you can't sleep, this works very well!
https://repositories.lib.utexas.edu...MASTERSREPORT-2016.pdf?sequence=1&isAllowed=y
My butt dyno and hand calculated MPG indicate more HP and better FE with this mod.
The other benefit, the exhaust manifold and turbo cool slower on shut down. At one point, my truck tuner had a turbo cooling feature. The truck would idle until the EGT dropped to the set point. I no longer have or use this feature.
As mentioned, my CTD turbo has 265,000 miles on it. Under normal use, these turbos last 350,000 miles. The cast iron exhaust manifolds are known to crack much sooner. I believe my exhaust manifold is lasting because of the exhaust manifold blanket. On a stock tune, these turbos run at 32 PSI pulling loads up mountains. EGTs up to 1200F is considered normal. Imagine shutting down a 1200 F cast iron E manifold and turbo! Bad things can happen.
A turbo blanket may increase the life of our Mazda turbos, decrease turbo lag, increase HP and FE.
I'll start a CX 5 turbo blanket post with observed results in the next few months.
We have trans tuning on our trucks. We change the shift RPM, upshift and downshift. Also change the trans pressures to firm up the shift. My old 48RE trans with performance shift kit is wife neck snapping firm when solo. When towing 10K, it's smooth as silk. It's programed for the upshift and down shift to keep the engine in peak torque. It seems like Dodge programed the trans to pass EPA emissions at the expense of the engine and trans. I wouldn't be surprised if Mazda was under similar constraints.
In yet another world, drag racing, we use standalone TCUs to control electronic trans with a performance valve body. We have seen some nice gains with trans tuning and increased the life of the trans. We control torque converter lockup and unlock, shift pressures and shift RPM.
Wish, hope, we get trans tuning down the road. That could be a game changer.
Until then, I'm very happy with our CX 5. What a cool machine!
Absolutely! DRTunee and I have been in conversation. He seems to be very knowledgeable and easy to work with.Indeed, I am exceedingly happy with my 6 as well. The NA Skyactiv is a bit of a beast with the remap. It feels like it is making more torque at 2500rpm than any other rpm! I was getting a solid 4L/100km with the cruise control set at 60km/h today. Impressive engineering.
I think Mazda overall did a good job tuning the throttle and AT on this vehicle according to a variety of real world constraints and scenarios. I will usually only override its shifting behaviour in manual mode for very specific reasons, such as approaching a hill which it is not aware of, or trying to draw out a gear without it forcing an upshift on me.
I used the manual mode far more frequently, thinking the transmission is too conservative, until I saw what the ignition timing and knock control looked like under those scenarios. I realized that the AT is doing so for a reason and stopped interfering.
As for cold start scenarios, there is one of three for me:
1. Start up. Put it into gear. Roll out without throttle for about 30 seconds while it is heating up the cat. Set off, driving gentle and steady.
2. Start the car. let it roll out the driveway in neutral. (The ECU detects your rolling and avoids the aggressive cat warm up idling.) I take advantage of this and pop the AT into drive to reduce drivetrain wear. take off. This is my favorite option.
3. Let it idle until the idle settles.
I'll do any of the three scenarios, depending on conditions, how the engine sounds, etc.
@AL Cx5 Let me know if you'd like for me to write up a quick review regarding DRTuned and my experience with him. Take the plunge; its well worth it!
Assuming appropriate TCM control software does become available I will be offering transmission tuning through Drtuned. There are some fun things we can do with the right control.Wish, hope, we get trans tuning down the road. That could be a game changer.
A few things i've observed..Absolutely! DRTunee and I have been in conversation. He seems to be very knowledgeable and easy to work with.
Another simple mod we do on Gen3 Hemis to 2.4l NA Honda's, add grounding to the heads and throttle body. I added grounds to a friends Mazda years ago. She didn't give me much fees back and drove it 280,000 miles. This mod was instantly noticeable on our 09 Accord.
We have measured some small gains with well placed ground cables using chassis dynos. 8 to 10 HP.
This is on my CX5 list as well....
Yes sir, my logging shows around 10-11 at WOT. Daniel leaned this figure out a little. I haven't seen what the figure is in the revision file yet.It would be interesting to know the afr at WOT too.
It would be I interesting to see a before and after chassis dyno of your car. With and without the 2nd cat and down pipe.
With the condition the second cat was in, no doubt it would.I'm surprised the power band moved lower with less exhaust back pressure. Not sure why that happened but sounds like you like it.
Daniel has pointed out that cat-backs help optimize Skyactiv tuning.A chassis dyno will show peak torque and HP and confirm the tune and exhaust changes. I've rented dynos for this reason many times.
Daniel has mentioned it part of the end-result goal for tuning, so long as it is not persistent or excessive of course. Ignition timing on the Skyactiv NA is generous under ideal circumstances. I have seen it at 40 degrees plus steady while cruisingI would be very concerned to see the knock sensors pulling timing.
Do some research and see if the factory downpipe on your 2.5T is restrictive. (It's probably not)I'm so new to the Mazda platform and haven't looked for high flow cats. I'm assume they exist for Mazdas. Did your tuner tune off a O2 sensor so that you could delete a cat?
Electrically grounding? Never heard of that. Everything electronic should already have a ground. What benefit would this have?I'll be experimenting with grounding the engine and a turbo blanket.
This grounding use to be called Hyper Grounding on imports. It's been around for years. I've hyper grounded Honda's, Nissan's, Toyota's and 1 Mazda. It worked just as well on Domestic gas burners. They all picked up around 8 whp and 2 mpg. Newer models are better grounded. It may not help. I'll do some before and after logs and post the results. If the Mazda community rejects this as a valid mod, so be it. I'll keep enjoying.
May I suggest reading the tech paper. The physics works the same on a 2.5 l gas burner turbo as a 6.7 l diesel. Lots of turbo blankets on race cars. It's applied heat vs universal heat. As mentioned, this is counter intuitive.
On my CTD the turbo blanket REDUCED Egts because of improved efficiency on the hot side. I live in Alabama and tow a 10,000 pound toy box. Total package weight with truck, trailer and crew, +16,000 pounds or +4xs the weight of a CX5. I have an egt and boost gauges on a DD dash. With the blankets egt is lower at the same amount of boost. The tech paper goes into detail why. Even a Mazda could benift from this mod. We will see...
I'll do some testing and show my results. I have a test route I use to test my 5.9 CTD for checking better FE. I'll use this on the CX5 T. Maybe do a few wot logs too. And wot is not where it's at on this CX5 for me. More of a cruiser, grocery getter.
I'm not much for doing a lot of wot tests. I accelerated the demise of my trans in my truck doing wot tests. It lasted only 230,000 miles. On the other hand, the refreshed 48re trans puts a smile on my face everytime I drive my tow pig!
Pretty much the entire tuning of this drivetrain is focused around low to mid range torque. Removing that cat should only exacerbate this.Historically, less restrictive exhaust moves peak HP to higher RPM and less low RPM torque. Maybe your 2nd cat was severely restricted.
I think it's a combination of repeated WOT runs earlier on the vehicles life, using 87 octane fuel, further exacerbated by the stock rich WOT conditions to try and modulate EGT.Makes me wonder why the 2nd cat failed?
I'm still wrapping my head around how many of the unique Mazda features work.Pretty much the entire tuning of this drivetrain is focused around low to mid range torque. Removing that cat should only exacerbate this.
That's not to say torque isn't strong across the rev range. I typically don't rev past 5000rpm unless the engine "sounds" like it's capable of doing so in the moment.
