They did match and set for local pickup. They did ping me with the Rock Auto shipping charge but still well worth it. $48.83 total.Yes, Advanced will match Rock Auto's price. Just chat with their customer service online. They will ask you for Rock Auto's link and you provide it to them. Plus Advanced is an authorized dealer per NGK.
More Information for NGK 94124
www.rockauto.com
Don't know if they're value or not. Part# on invoice is PY8V-18-110.With current high dealer labor rate, this’s a great price if the dealer didn’t use the OEM “Value” spark plugs like they always use OEM “Value” oil filter when they do the oil change.
See post #7 above.
Are these plugs ready to install or do they have to set like the old plugs (spark plug gap)?
ngksparkplugs.com
For ATF and gear lube changes, if you prefer not to DIY, try to find a good indy shop familiar with Mazda to do them for you. Yoh can buy correct OEM fluids ATF FZ (~14 quarts for 3X D&F including a pan drop for filter change) and gear oil SG1 (~1.2 quart F&R). And:So it sounds like it's time to do the gear oil in the front transfer case (not done yet) and again in the rear differential (done at 35k). Then also do a drain-and-fill for Mazda’s SkyActiv-Drive automatic transmission. I don't have the tools or place to do this myself so I'd need to go in somewhere.
I got genuine Mazda fluid in liters from Mazdashop online - they had the best price and it was half what my local dealership in Florida is charging.
Make sure to have a 14 mm thin-wall spark plug socket and a ⅜“ torque wrench (even a cheap one from Harbor Freight Tools) capable of the spark plug torque spec 12~14 ft/lbf.Watched a video on the spark plug replacement and it looks easy enough. The last car I did this on was a '94 Celica. A bit easier but it still doesn't look difficult.
They’re “pre-gapped” but I usually would verify the gap with the spark plug wire gap tool. Be careful not to damage the tip.Are these plugs ready to install or do they have to set like the old plugs (spark plug gap)?
Labor was $39.00
Maybe somebody on here knows.
You should have got “normal” Mazda OEM spark plugs for the 2.5T. Part no. PY8V-18-110-MV is the “Value” plug for the 2.5T. $39 on dealer labor that‘s only ¼ hour! You got yourself an honest Mazda dealer!Don't know if they're value or not. Part# on invoice is PY8V-18-110.
Labor was $39.00
Anti-seize, the guy at Adv Auto Parts asked me my make/model before heading out the door then gave me a little packet of anti-seize compound.For ATF and gear lube changes, if you prefer not to DIY, try to find a good indy shop familiar with Mazda to do them for you. Yoh can buy correct OEM fluids ATF FZ (~14 quarts for 3X D&F including a pan drop for filter change) and gear oil SG1 (~1.2 quart F&R). And:
ATF...Change or not?
And don’t use anti-seize compound on spark plugs.
I bought 4 x NGK 94124. Wrong?You should have got “normal” Mazda OEM spark plugs for the 2.5T. Part no. PY8V-18-110-MV is the “Value” plug for the 2.5T. $39 on dealer labor that‘s only ¼ hour! You got yourself an honest Mazda dealer!
No, I have not. Plus I don't have any decent setup around home to do this.Aside from spark plugs, have you ever drained/filled transmission fluid?
Also I agree with @yrwei52 - check your belt tensioner for leaks.
Don't use anti seize. NGK does not recommend it.Anti-seize, the guy at Adv Auto Parts asked me my make/model before heading out the door then gave me a little packet of anti-seize compound.
ngksparkplugs.com
The belt tensioner is on the serpentine belt near the alternator at the right (passenger) side of the engine. It would look wet like mine here:⋯
Leaks? Is this on a belt or tensioner itself? Where to look exactly?
IMO $149 for radiator flush “with cleaner”(?) from a Mazda dealer seems to be reasonable. Make sure they use FL-22 coolant. But the first coolant change is scheduled at 120K miles / 10 years, and 60K miles / 5 years for subsequent coolant change. At 74k miles and 7 years on your 2016.5 CX-5 this service is too early for you.So today I'm just getting at the traditional service then with the car wash. I'll do the plugs myself. They don't even touch transmissions here since they consider them lifetime. Not worth the risk the service manager says. Got to know the guy over time. So that would have to be done elsewhere. Although other Mazda dealerships will do that.
Here's the pricing we're looking at for a few other items on the list:
-radiator flush with cleaner $149
-front transfer case $139
-rear differential $113
-I'm not going to have them do the fuel injection cleaning service. I've seen that Chevron Techron injector cleaner at Costco in the past. Does it matter whether to do this service before or after spark plug change?
Thank you for your feedback. I appreciate it! What are your thoughts on the control arms and tire rods?IMO $149 for radiator flush “with cleaner”(?) from a Mazda dealer seems to be reasonable. Make sure they use FL-22 coolant. But the first coolant change is scheduled at 120K miles / 10 years, and 60K miles / 5 years for subsequent coolant change. At 74k miles and 7 years on your 2016.5 CX-5 this service is too early for you.
Front transfer case $139 and rear differential $113 are pretty high IMO. You can buy 2 bottles of Mazda SG-1 gear oil (<$50?) and find a good repair shop to do both for less than 30 minutes.
You need to find some Mazda dealer (like my Mazda dealer) or good repair shop to do the ATF drain-and-fill for you.
Check those Mazda dealers’ website and see if there’re service discount coupons for your needs.
Yes you can get a box of Chevron Techron injector cleaner at Costco. Follow the instruction and do it at your next fuel stop. Use Top-Tier gas like Costco and it doesn’t matter you do this before or after the spark plug change.
Control arms and tie rods? Unless you have obvious problems such as torn boots or clunking noise, I doubt you need to do anything on them at 74K miles.Thank you for your feedback. I appreciate it! What are your thoughts on the control arms and tire rods?
So the coolant change is too soon then.hmm
Mazda service manager told me they would do the tranny fluid drain/fill if the vehicle was out of Powertrain warranty. I think I will find an Indy shop to do the tranny fluid.So today I'm just getting the oil service/inspection and then car wash. I'll do the plugs myself. They don't even touch transmissions here since they consider them sealed and lifetime. Not worth the risk the service manager says. I've come to know this guy over time. So that would have to be done elsewhere. Although other Mazda dealerships will do that he said.
Here's the pricing we're looking at for a few other items on the list: (prices are pre-tax)
-rear differential $113 (can wait, first time was done at 64k miles)
-Mazda recommending brake fluid flush $140 (they say pads are at 6mm and due at 3mm, seems the flush be done rather than wait for brakes, their recommendation)
-I'm not going to have them do the fuel injection cleaning service. I've seen that Chevron Techron injector cleaner at Costco in the past. Not sure if they still have it. Does it matter whether to do this service before or after spark plug change?
They do have down as needing attention (photos available). They suggest doing the following within the next 5k to 10k mi:
-front outer tie rods (Front outer tie rods beginning to crack/rip and leak recommend replacing once worse - No action needed this visit). $375. Inc tax.
-front lower control arms (Front lower control arm balls joints beginning to leak and crack/rip recommend replacing once worse - No action needed this visit). $1028. Inc tax.
-alignment after above work $119, before tax
-belt tensioner -> looks fine, no issues, clean
-VVT solenoid oil control valve-> looks good. Dry, no leaks.
