2017~2024 CX-5 H&R or Eibach lowering springs?
That is weird, though I have a 14' model, I'm lowered 3-1/4" and I don't have this issue. I have just installed Koni Yellows.
I'm curious if the 1st gen OEM shocks are shorter. The Koni's most likely have a shorter Body
If you don't mind, could you measure the shock body on the OEM ? And maybe the Koni aswell if you can?
@shox75 I just did my installed. First time working on it by myself. I got the front down but the rear, how to you take the bump stop out to cut? I can get the shock absorber out then how do I pull it apart?
The nut at the top, you loosen it. Impact gun helps with this. After you can pull off the top plate with bump stop.
Having a rear driver side knock/noise as shown in the video I’ve attached. Wondering if it’s the shock dust cover that’s knocking and making this noise. Lowered on corksport springs.
I think I can see the dust cover move. To isolate the issue, maybe wrap a towel around the shock body to prevent the cover from making contact.
Dang, this thread has been super informative and the definition of scope creep. I came here thinking I’d do the springs on my ‘20 GTR and now it seems I also have to do bump stops, alignment, rear camber arms, and maybe shocks? Well, the more you know... 😂
I ordered Koni Special Active struts for my 2015 CX-5 (GT AWD) and was looking into the Eibach Pro-Kits, can anyone let me know what the model number is that would fit this car? Thanks
@Oracle you will want to double check of course.. but looking at the Knowledge Sharing document...
It looks like the part number for Eibach Pro-Kits you need is: E10-55-014-01-22
2.0 AWD [110kW/150HP] E10-55-014-01-22GEN1
2.0 AWD [113kW/154HP] E10-55-014-01-22GEN1
2.0 AWD [114kW/155HP] E10-55-014-01-22GEN1
2.0 AWD [115kW/156HP] E10-55-014-01-22GEN1
2.0 AWD [116kW/158HP] E10-55-014-01-22GEN1
2.0 AWD [118kW/160HP] E10-55-014-01-22GEN1
Thanks for sharing. It looks like E10-55-014-02-22 for 2.5 AWD [136kW/185HP] is the one, I went ahead and ordered this one from the EU.
Rays Gram Lights 57Transcend 19x8.5 38et
Firestone Firehawk Indy 500 245/50/19
username: " sig cx-5 "
Does anyone who lowered their vehicles, notice any gas milage improvement?
Hypothetically it should improve. Curious how by much..?
Latest posts
