CX-5 Battery Replacement recommendation?
MEB
16.5 GT w/Tech AWD
I need a new battery for my 2016.5 GT AWD CX5. I am replacing the original battery, so this is my first new battery experience. Should I go with the "Mazda" battery @ my dealer 2yr replacement warranty / 84MO (prorated) warranty $250, includes labor.
If I buy on my own, what brands & specs. should I consider beyond the right type / size for my CX5? Will I need to "re-set" or lose any existing saved functions with a new install?
I need to replace within the next 5 business days. I'm the orig. owner of the car. It has 48K miles & I've not had any issues with the original battery. I live in the Seattle WA area and my car is not garaged. I plan to keep this car for 2 yrs.
Thanks for your recs!
These "discount auto parts" stores are all a sham with their overinflated pricing. NOTHING discounted at all and most items can be found on rockauto for much much lower or amazon if in a pinch. I LMAO at their prices, coupons or not, they're way above reality IN FANTASY LAND. For example, I needed to purchase a simple coolant temp sensor for a 2006 honda civic. Local autozone, advance or O'Reilly's wanted $55 to $60 for that. Rockauto they're $15 to $20 for a good brand. Same brand on amazon, $25. In no way does it justify a store to charge nearly triple for something. If Costco can sell this battery for $125, then you know how much markup there is at these "discount stores and how much money is burned if a person doesn't know any better.
These things are easy to install folks. Learn it once, get the knowledge and satisfaction and be smarter for life.
Yes, I buy from at parts stores only when I'm in a pinch. Like oil, ATF or coolant.
As a rule, I don't buy any sensors from Rock or parts stores. I tested several in the past and they have different resistance and magnetic strength than oem. Other sensors were longer and hit the reluctor wheel, killing them.
I have a closet full of bloody t shirts from cheap, parts stores sensors.
Just because they don't throw a code doesn't mean they are in calibration. Been there too...
Upvote 0
A closet full of bloody shirts, eh?
Perhaps your installation methods need a bit of adjustment?
I would suggest wearing red shirts whenever you work on your cars.
Upvote 0
what did you go with? the 250 sounded good to me,you dont touch it and you got 9 years from the other one
Upvote 0
I bought a battery from costco and replaced it myself using a 10mm wrench in less than 20 min. It was the first time I changed a battery.
So long as your battery does not corrode badly at the terminals, if you want your battery to last, hook it up to a tender when the car sits for long periods, esp. in cold weather, after short distance drives, that should help the battery last longer than what battery you buy,
Upvote 0
Upvote 0
Huh went down a buck. Pretty sure I paid $125 even plus tax in 2023 when I replaced a Costo Interstate I had bought for $75 in 2018 which replaced the original battery.
I'm on my 3rd battery. So far so good on this one.
+1 for its easy to replace yourself. Remember you'll need a 10mm deep socket for the bar that goes accross the battery to hold it in place. The nut sits fairly far down on the threads so a regular socket can't reach.
Upvote 0
you get around 5 years from each battery? I use that mark to replace mine ,never had any issue's yet
Upvote 0
On my previous car, a Mazda CX-5 GT AWD Premium Plus, the last battery I've installed was an AGM battery 665 CCA or something around that number. I can't remember exactly. But it was AGM, group 35 over 650 CCA. It worked flawlessly.
Upvote 0
My current one purchased in ‘22 from Costco was $99
I have a couple old batteries that allows me to wheel in a core at purchase time.
It is still showing around 95% health using my tester. I usually replace them when health has dropped to 75-80%
Upvote 0
I recently had to replace mine. I tried the Costco Interstate option to save money (I thought). I choose an AGM so they are bit more than $120. That battery failed after only 2 months. Gave it back to Costco and got a full refund (even gave my core credit back). Went to Mazda shop and bought a fresh OEM (was just delivered that day). The cost of the OEM where I live was only a few dollars more than the Costco offering (of the AGM).
Upvote 0
Interesting. I'm 3 years into my 2nd Interstate from Costco. First one lasted 5 years.
Upvote 0
