CX-5 Battery Replacement recommendation?
MEB
16.5 GT w/Tech AWD
I need a new battery for my 2016.5 GT AWD CX5. I am replacing the original battery, so this is my first new battery experience. Should I go with the "Mazda" battery @ my dealer 2yr replacement warranty / 84MO (prorated) warranty $250, includes labor.
If I buy on my own, what brands & specs. should I consider beyond the right type / size for my CX5? Will I need to "re-set" or lose any existing saved functions with a new install?
I need to replace within the next 5 business days. I'm the orig. owner of the car. It has 48K miles & I've not had any issues with the original battery. I live in the Seattle WA area and my car is not garaged. I plan to keep this car for 2 yrs.
Thanks for your recs!
Group 35 is what you're looking for ...
Walmart EverStart Maxx $140
They also have a Weize AGM at Walmart for $135 ... That's a great price !
Costco, Sam's club, Walmart etc will probably install it for free as well.
9 years on your oem battery is amazing 👍 and only 48k miles on your 2016.5 is a gem of a car. That'll make a VERY NICE hand-me-down to a kid or niece/nephew/family member/friend etc when you're done with it. Best year CX5 made fo sho! 😁
Upvote 0
Any AGM battery that has the correct rating.
Personally I buy batteries from Advance Auto. I buy their DieHard AMG batteries. AMG batteries last longer and do leak acid on your battery connectors and car. They are more vibration resistant and don't need water added. Clean, corrosion free battery connects are important on cars these days with all the electronics.
Advance Auto warranty is REPLACEMENT, not prorated. They replace the battery, no questions. They have different price points but its the same exact battery. You pay for longer warranty as the price goes up.
In my area there seems to be an AutoZone on every corner. So if it goes out, I can pull into a store and they warrant the battery. So far I've not used their warranty...
If the store will put a jump box on the battery connectors and carefully remove them, then you won't lose your settings. It adds to the complexity but it works. The chains are more about slapping the battery in and slamming the hood.
I've taken the tools from the "tech" at these stores before and bring my own and asked them to step back so I can install the battery...:p
Upvote 0
I'm still on the original battery in my 2016.5 as well. It's still going strong and has not shown any signs of slowing down, yet.
I just turned 40k miles the other day. I suppose that it's time for a new battery and a fluid exchange in the trans. Too hot though, maybe this fall.
Upvote 0
I'll second all of the above recommendations for the Walmart Everstart Maxx. Much better price for a lead-acid than the auto parts stores. My Costco won't even remove the old battery and install the one they just sold you. I said to them" what about if some little old lady needs a battery". The answer was for her to get someone to do the swap. Screw that. I went to Walmart who at least does the installation and has been good to deal with for other things. I needed a battery NOW and was in and out within an hour on a Saturday. Besides, I've been reading about the Interstate that Costco sells does not have the reliability of the older Interstate batteries. Maybe something has changed. And the price difference between Walmart and Costco was negligible. Just my experience.
Upvote 0
Upvote 0
Thanks for all the recs! I went with walmart Everstart Maxx they installed today.
I have noticed some of my settings went awry or back to factory setting: headlights; auto setting, my dash lights now dim to darkness when headlights are turned on...and likely other stuff I haven't noticed yet. I'll review the manual, since it's been 8 yrs ...LOL to see if I can fig those out. Feeling I don't know what I DK until I need something.🤷‍♀️
My auto up/down driver window (as noted by others) doesn't function and after following directions, still doesn't work.
Hopefully the safety features are still working.
I'll check back if I cant fig. things out.
Thanks again everyone!
So appreciative of this forum and yr knowledge sharing! Pls Stay Human! ☺️
Upvote 0
RE: age..Battery life; I know I rechecked my maintenance rcpts to be sure! It's why i initially asked if I should go w/a maza battery. miles; I work from home so no commute & COVID played a part in low miles too. I've been very happy with this rig., first MAZDA.
Upvote 0
I have noticed some of my settings went awry or back to factory setting: ... My auto up/down driver window (as noted by others) doesn't function and after following directions, still doesn't work.
Check the instructions @ p3-33 in the 2016 owners manual. Describes the reset procedure for the power windows "automatic" function, if the battery gets swapped.
Power window system initialization procedure
If the battery was disconnected during vehicle maintenance, or for other reasons (such as a switch continues to be operated after the window is fully open/closed), the window will not fully open and close automatically.
The power window auto function will only resume on the power window that has been reset.
  1. Switch the ignition ON.
  2. Make sure that the power window lock switch located on the driver's door is not depressed.
  3. Press the switch and fully open the window.
  4. Pull up the switch to fully close the window and continue holding the switch for about 2 seconds after the window fully closed.
Upvote 0
Upvote 0
These "discount auto parts" stores are all a sham with their overinflated pricing. NOTHING discounted at all and most items can be found on rockauto for much much lower or amazon if in a pinch. I LMAO at their prices, coupons or not, they're way above reality IN FANTASY LAND. For example, I needed to purchase a simple coolant temp sensor for a 2006 honda civic. Local autozone, advance or O'Reilly's wanted $55 to $60 for that. Rockauto they're $15 to $20 for a good brand. Same brand on amazon, $25. In no way does it justify a store to charge nearly triple for something. If Costco can sell this battery for $125, then you know how much markup there is at these "discount stores and how much money is burned if a person doesn't know any better.
These things are easy to install folks. Learn it once, get the knowledge and satisfaction and be smarter for life.
Upvote 0
Well, I wouldn't say that. I do a lot of shopping at Advance, and often use their coupon codes for 15-20% off. And I'm also a Speed Perks member, and I'm constantly getting $5 and $10 coupons. Stacking the Speed Perks rewards on top of the whatever % off and the prices are usually right in line with Rock Auto, and I don't have to wait.
Upvote 0
Costco all day long. Interstate for $120 or less
Used to recommend getting the Intestate Group 35 battery at Costco for the best value. But Costco has increased the price from $78.99 with 36-month replacement / 60-month prorated warranty before pandemic, to $123.99 with only 36-month prorated warranty. Not worth it now.
Upvote 0
