Crazee 4 tha darkside...
i think the hole in the middle isnt to bad if you have a giant fmic, but those sides are fugly. maby get them molded with some fogs or some cf splitters.
Not to derail this thread too much but if you check out their site you will see they have foglight holders to fill in those side holes. Also do a search for "Accolade" here and you should see some threads with pics of the kit. Even the Perrin FMIC, which had the largest core of any kit made for the Protege looks small in that hole.
But anyway, any new ideas as for an oil cooler? I'm really thinking about getting one as well but the only place I can think of putting one would be just above the IC in the front which would require a lot of extraneous lines.
Where do the lines come from on an oil cooler? Would it be fed from a sandwich plate, then to the oil pan.
In all seriousness you should look into getting the front bumper from Accolade.
Plenty of airflow on that biznitch.....lol
DAYUM! That is a big gapin hole
That is an option. Check the link I posted for the oil cooler discussion thread.
^^^ LOL I've contemplated getting that kit many, many times. I like the lines but that whole in the front is just too damned big! Even my huge turbolife FMIC won't fill that. But you are right; that would leave lots of space to put stuff. I wonder if it would be possible for a body shop the close up that hole in the front a little...?
I was thinking the same thing...but the rest looks pretty good.
Well you could get creative and make some channels around the intercooler to divert airflow to the various Coolers.
subbin
looks like you and me are on the path i'm putting together my turbo kit as well
Not a good update...
Car is out of comission for now.
It stalled as I pulled in the gas station to fill up.
Wouldn't restart before or after I added gas.
Got towed to shop now :(
could not hear fuel pump turning on
mechanic sed pump is not running, but no spark either and the OBD reader didnt work or something
hoping its the fuel pump relay... TBD
are you running a split second FTC?
this same issue happened to my buddy, the ftc burned up some wiring and fried his ecu in the process....no spark, car wouldn't start, fuel pump wasn't turning on, no blown fuses
hope you figure it out
sub'n
marathon update...return of the misfire
Thanks for the support guys. Well, here's a mixed update:
Once upon a time, I had a second O2 sensor placed behind my hi-flo cat using an MSP extension harness. Fast forward 2 years or so, and the harness has managed to get free and is hanging down sometimes dragging on the ground. I take up the slack in the line but never "inspected" for damage. Well, it shorted out and blew out the fuseable link in the ECU wiring harness (UGH!).
I had it TOWED to the mechanic, who figured out what happened and fixed it. (chair)
I also badly need to get passed at state inspection. I've already racked up 2 tickets and 2 warnings for my expired inspection.
For starters, we HAD to quiet her down. Chris (mechanic) suggested DYNOMAX mufflers for their superior flow (mo' CFM).
I ordered up a threesome, 2 bullet mufflers, installed inline as resonators/pre-mufflers and an UltraFlo canister. All 2-1/2" diameter.
He replaced everything rearward of the cat. New metallic core cat when the snail goes in. Ractive can was cut off, probably killing its resale :(
Anywho, it attracts much less attention now than it did with the Fart Can buzzing away. Still loud in the cabin but has a deeper tone from outside. You can still tell when I floor it that it ain't stock (angel). But, it should appear stock enough to pass inspection. I hope.
Well, I also need to clear my CEL for Random Misfires. At this point we think the very lopey idle is causing the ECU to think it is misfiring. Code goes away at higher idle speeds. Inspection requires 950rpm idle max. We tried restricting the airflow also.
We had thought replacing the screws in the kasman adj cam gears might help the CPS pickup get a good reading. We are still waiting for some assorted sizes to arrive. The screws it comes with may be a lower quality steel.
This morning the squeely alt belt shredded :( We knew it was getting chewed up. Damn these AL pullies! Chris keeps telling me to put the stockers back on.
Decided it was time to bite the bullet and get a "R" inspection Rejection sticker and have them do the belt since its been raining all day.
Brakes are ****** up again, Lots of new rattles and clunks all over.
oye I need a drink
(beer)
However, I have been picking up pieces for wiring up a sub in the trunk.(ricer)
2 x 10" JL Audios, a Kenwood amp, fuseholder and now just terminals and connectors.
** anyone used www.hifisoundconnection.com ?? **
I ordered some #2 gauge battery wire through work for relocating the yellowtop to the spare recess. Probably like to mount it laying flat and I can use the side posts too. (rx7 how to: http://www.stanford.edu/~sunid/battery/)
Looking into some nice #8 Power and #10 O2 free wires. I may sell my extra here on the forums! :D
ALSO, I spoke with DocB!! Tom is a great guy and was verying patient with all my questions. I should do a post about my chat with him and what I learned.
Basically, I confirmed that the correct size oil adapter (20mx1.5)
-10 AN lines for oil lines and if I go with an oil cooler/thermostat to route to the PRV first then to filter-thermo-cooler-return.
He also tells me the oil press sending port in the back of the block is a good place to pick up oil to send to the turbo.
I am just concerned about TOO much oil press sent to the turbo.
I did a fair amount of shopping and found a deal on a spin on adapter and remote oil filter mount. I even bought an extra of each to resell.
send me some information about what your using to relocate the filter please, I'm doing the same myself in the next month
